dwyermcalaster
ye cant bait the smell of 2 stroke
Post by dwyermcalaster on Nov 12, 2010 22:48:52 GMT 1
hi lads petrol leeking tiny bit out of bleed screws for carbs have as tight as i can get but still leeking small bit any thing i can put in to stop this
Post by elsie1411 on Nov 12, 2010 23:56:24 GMT 1
try and check the float heights as it may be from the over flow or sticky inlet needles
Post by looey on Nov 13, 2010 10:23:46 GMT 1
The float bowl drain screw right at the bottom ?.
dwyermcalaster
Post by dwyermcalaster on Nov 13, 2010 14:46:06 GMT 1
The float bowl drain screw right at the bottom ?. ye mateleekingandheadon screwf**kedcant tightenany more
dwyermcalaster
Post by dwyermcalaster on Nov 13, 2010 14:48:30 GMT 1
try and check the float heights as it may be from the over flow or sticky inlet needles cheers lovetherd butwouldbreak a mansheartevery timeigo away from it find something else to do or needs to be done better
Post by lcowner on Nov 13, 2010 15:30:18 GMT 1
try and check the float heights as it may be from the over flow or sticky inlet needles cheers lovetherd butwouldbreak a mansheartevery timeigo away from it find something else to do or needs to be done better it will be all worth it in the end
