dwyermcalaster
ye cant bait the smell of 2 stroke
Post by dwyermcalaster on Oct 12, 2010 19:00:54 GMT 1
hello new to this site. have a rd350 lc after only being driven for about 10 minutes coolant bone . any one any ideas or help for me thanks
dwyermcalaster
Post by dwyermcalaster on Oct 12, 2010 19:01:44 GMT 1
bone dry i ment
dwyermcalaster
Post by dwyermcalaster on Oct 12, 2010 19:24:24 GMT 1
ye john it was full and once i got off it was near empty. the tempature gage didn move much . have only joined site love the lc,s but dont know a major amount about them. not a female must have just hit the wrong thing when sign up
dwyermcalaster
Post by dwyermcalaster on Oct 12, 2010 19:30:12 GMT 1
have a look in ya gear box ...that happend to me a few weeks ago my impler was shagged....cheers john what is the impler , can do chain sprockets and the basics learning as i go with project
dwyermcalaster
Post by dwyermcalaster on Oct 12, 2010 20:12:57 GMT 1
on the right hand side there is a plastic cover mounted by 3 screws remove that cover and you will see a second cover the one the rubber hose goes to there is 5 or 6 screws holding that on. your impeller is behind that. this is the cover at the upper end of the pic jes fair play picture and all how can i tell if gone
dwyermcalaster
Post by dwyermcalaster on Oct 12, 2010 21:00:08 GMT 1
before u take the cover off have you checked ur oil leveletc.? ye oil seems ok it just seems to be near empty after about ten minutes
dwyermcalaster
Post by dwyermcalaster on Oct 12, 2010 21:14:48 GMT 1
If you take the impeller cover off look for anything which looks out of place. you will loose any remaining water. the impeller is driven by a plastic gear on the inside of the casing so you should not be able to turn it by hand. however i think it would turn if you use the kick start. try that that my prove the gear assembly may be intacted. on for sure way is remove the whole casing and inspect. btm we'll try the other options cheers mate appricated
