chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on Oct 9, 2010 8:05:10 GMT 1
i just read an article that says 400 a/c barrels fit straight on a 4lo crankcase with no drama my questionis why do it? has anyone tried this out if so were there any advantages?
Post by gazzatt2 on Oct 9, 2010 12:27:34 GMT 1
i just read an article that says 400 a/c barrels fit straight on a 4lo crankcase with no drama my questionis why do it? has anyone tried this out if so were there any advantages? 400 stroke is different
dezcbr
Post by dezcbr on Oct 9, 2010 17:18:48 GMT 1
Years ago at Sherburn/Squires cafe i saw an aircooled bottom end not sure if it was 250 or 400 fitted with a LC top end, spoke to lad riding it and he reckoned he had done the conversion as aircooled bottom ends are stronger than LC's.
Post by gazzatt2 on Oct 9, 2010 19:36:24 GMT 1
A/C 250 and 350 is same stroke as LC 250/50 swoppiong barrels either way can be done
A/C cranks are splined not a taper press fit like LC so do not twist
Post by JonW on Oct 11, 2010 23:52:02 GMT 1
I was offered an aircooled top end for use on my LC bottom end, seemed like it was the wrong swap... less string crank and lesser top end tune, but would have been an interesting bike I guess as no water, no rad, no pipes etc in an LC means less weight etc.
Post by Norbo on Oct 12, 2010 6:40:13 GMT 1
well dispite the crank being better its step backwards on power. but it would have been intoresting to look at in a lc frame ./
Post by JonW on Oct 12, 2010 22:33:00 GMT 1
Yep true, but with the LCs frame/body weight the performance would have been terrible i recokon :/
