Post by richardroberts on Sept 4, 2010 18:51:11 GMT 1
my lc125 wont go past 80. tryed a allspeed, but still only 80 any ideas
Post by billy on Sept 4, 2010 20:24:24 GMT 1
Is the jetting OK? My LC was too rich once, I hit 90 mph and no more. Couldn't stay in the powerband on 6th gear unless I gunned it from start (which I never did cos back then it was WAAAAY too wobbly) Then I changed for smaller main jets (went from 280 to 260) and it ran ALOT better in higher speeds.
Also, perhaps you have to rejet for the Allspeed pipe? Anyway, if it's not the jetting then perhaps this:
Bore and piston OK? How much compression?
Crank seals and gaskets OK?
Do the reeds close properly?
Have the cylinder been ported, and if so, what has been done to it?
Can't think of anything else that could go terribly wrong. But on the other hand, I'm not sure if 80 mph is actually that bad. I thought these bikes didn't go much faster then 90-ish mph?
Post by richardroberts on Sept 4, 2010 22:41:29 GMT 1
was running a 12a carb with 210 jet thinner foam filter in standed box. and hy tech reeds n allspeed :/
