Post by jasper2608 on Aug 6, 2010 8:23:40 GMT 1
i need the part numbers for the circlips on rd125lc mk1 clutch side of engine only the circlips that have to be taken off to split the bottom end wish i could be more presice (only ones needed to be taken off to split the bottom end) thanks
Post by jasper2608 on Aug 6, 2010 19:36:04 GMT 1
rang norbo but i couldnt give him enough info for the right circlips i aint clued up enough on the engines to give him the right info all i know is they have to be taken off clutch side b4 bottom end can be split thanks jasper
Post by mellow on Aug 6, 2010 20:38:44 GMT 1
Hi m8.I will email u parts fiche for mk1 then as u remove them or find out which u need u can look them up
Post by mellow on Aug 6, 2010 21:13:57 GMT 1
ok cancel that m8.file is too big to send to ur supplied email its 16mb.if u have an account that will accept files that big pm me the addy
Post by jasper2608 on Aug 6, 2010 21:50:20 GMT 1
or you could be really nice and look on the fiche clutch basket side of the engine all the circlips on that side all near the clutch basket i think there was 3 might be 4 doesnt sound good looks like im going to have fun trying to put this engine back together im ok when things are fresh in my mind but its been in bits for a while i was never really good at jigsaw puzzles lol
Post by mellow on Aug 6, 2010 21:56:05 GMT 1
ok m8 il try n sort it this weekend
Post by jasper2608 on Aug 6, 2010 21:56:54 GMT 1
thanks thats really good of you much appreciated thanks jasper
Post by mellow on Aug 9, 2010 20:43:21 GMT 1
right m8 been through fiche.This is the circlips on clutch side. Not sure which of these need removing.....perhaps gary or someone can say which 1) on kickstart shaft 93440-15012 2) on transmission shaft 93410-20038 3) " " 93440-15012 4) " " 93410-22039 5) shift cam fork 93430-08036 hopefully someone can confirm which u need to remove
Post by jasper2608 on Aug 9, 2010 20:46:40 GMT 1
cool thanks will make life a lot easier now i hope thanks jasper
Post by Deleted on Aug 11, 2010 23:17:46 GMT 1
i can email you the file ;D
Post by jasper2608 on Aug 13, 2010 20:32:37 GMT 1
is the transmission shaft the one that runs through the engine from the front sprocket
Post by jasper2608 on Aug 15, 2010 12:27:29 GMT 1
just split another engine a totally different way bearings must have been to tight on left hand casing to split it so i had to take circlips off right hand casing to split last engine this one i just knocked through front sprocket shaft a lot easier but circlip i need is on right hand casing and is on shaft that runs from front sprocket just below kickstart on other side is that the same one you are on about thanks
