Post by davey on Jun 23, 2010 9:57:10 GMT 1
hi all, my tzr r is running rich ive adjusted the screw on the carb and put in a new air filter, but the plug tells me its still running rich, it also miss fires badly from around 8000 rpm upwards in the higher gears, i cant seem to find any settings or data on this bike anywhere. its a 94 belgrada 4fl.(french model as ilive here) any help or advice would be great. thanks ,just to add that the carb has been rebuilt but it was by a french bike shop and it was ultrsound cleanedat the same time .
Dave
Post by carlos on Jun 23, 2010 17:09:23 GMT 1
probably needs a smaller main jet mate if the plug is black especially if it's at the top of the rev range!
Someone may have put a bigger jet in due to it running badly due to dirt and the ultrasound has removed all the dirt and make it run rich
Post by davey on Jun 24, 2010 13:30:29 GMT 1
ok mate thanks i will try , u dont happen to know what size jet is standard do u ,, as u can tell i have absolutly no experiance with these bikes , if were a porper lc i would have no probs
cheers a lot
Post by Norbo on Jul 28, 2010 11:05:56 GMT 1
bim meens moveing the clip up to lower the needle to weeken the mixture.
Post by davey on Mar 16, 2011 22:06:05 GMT 1
better late than never thanks for the advice guys , turned out that the french are c**ks ,, it was way overjetted ended up doing it my self a 210 main now will pull 11 grand in top
