Post by carlos on Jun 6, 2010 19:35:37 GMT 1
Right, I've decided to convert my mk2 125 into a powervalve, but could do with a bit of advice! I obviously need a powervalve barrel and head, I know the con rod is different, I'm going to have it "tuned" a touch and I'm going to run a different carb I also obviously need the powervalve control box, servo, cables, etc etc. Here's the questions! Are the cdi units and stators the same on the mk2 and 3 Rather than cutting the loom I intended to add the wiring for the control box so it could be replaced at a later date!
Post by mellow on Jun 6, 2010 22:06:27 GMT 1
u need a 1GU CDI m8
Post by twostroker on Jun 6, 2010 22:11:10 GMT 1
id buy a complete loom with controll box and cdi and powervalve pullyss off a working one as it could be trouble mix and matching odds and ends,garryRDrobbo will know for sure fella.
or even better you could just get your mk2 barrel resleeved to 175cc as it will be less to go wrong and probaly produce more torque,mine went pretty well and it didnt cost a great deal to get done.
Post by carlos on Jun 6, 2010 22:15:11 GMT 1
The aim is to run a tuned motor, but it should still have loads of bottom end with a working powervalve. and go like stink top end!
Post by carlos on Jun 7, 2010 21:22:52 GMT 1
YES YES YES !
EVERYONE WANTS YOU TO!
Post by carlos on Jun 7, 2010 21:46:58 GMT 1
i will be doing this shortly as mine is ready to be transplanted into my mk1 frame... i will show you loom differnces and tips and advice...please be patient as i have a bit to sort but i will do the whole thing from frame up... gaz Cheers Gaz, I was planning this as a winter project so take your time........
Post by carlos on Jun 18, 2010 16:42:19 GMT 1
UPDATE
The barrel I've got has had a 1mm rebore, and now Taymar is doing some tuning magic on it, he says the working powervalve will mean it keeps its bottom end whilst improving it loads from standard, I'm then going to have it polished to match the rest of the engine, then I'll put the barrel to one side, all oiled up nicely until I get some more pennies and source a CDI unit
