grunt
Post by grunt on May 25, 2010 20:37:35 GMT 1
best quality chain for my 125lc as the thing i got on just stretches as my bike isnt standard found a d.i.d performance one for £41 is that good thanks in advanced grunt
Post by Norbo on May 25, 2010 23:29:59 GMT 1
DID are excelent mate and that sounds like a good price as well .
Post by carlos on May 26, 2010 7:08:03 GMT 1
Keep the front wheel on the ground Grunt, that'll stop it stretching!
Also, make sure your wheel alignment is correct, if it's out it puts stresses on the chain.
A new chain on old sprockets wont last as long as replacing the whole lot!
grunt
Post by grunt on May 26, 2010 12:01:27 GMT 1
yes carlos well its slightly hard to when all i want to do is race and wheelie haha that £41 is for the chain and sproket set performance one the little saxo couldnt keep up yesterday night haha
gadget
Post by gadget on May 26, 2010 21:11:31 GMT 1
Grunt..... Iwiss chains are the dogs m8, had one on my brit single and they are notorious for bashing the f**k out of chains due to the 'yanking' inertia of a big single Hardly ever had to adjust it compaired to other chains iv'e used. ;D Anyway, iv'e seen your chain m8 it's like a metal stick ANYTHING you use will be a major improvement ;D ;D ;D ps..... you know that drag racing cars away from the lights is dangerous, not to mention illegal ;D ;D ;D
grunt
Post by grunt on May 26, 2010 23:15:28 GMT 1
Grunt..... Iwiss chains are the dogs m8, had one on my brit single and they are notorious for bashing the f**k out of chains due to the 'yanking' inertia of a big single Hardly ever had to adjust it compaired to other chains iv'e used. ;D Anyway, iv'e seen your chain m8 it's like a metal stick ANYTHING you use will be a major improvement ;D ;D ;D ps..... you know that drag racing cars away from the lights is dangerous, not to mention illegal ;D ;D ;D ok gadget guess i will have to replace that astra for my 125lc at the lights
Post by twostroker on May 27, 2010 18:46:05 GMT 1
you could always run a slightly larger pitch chain and sprocket
grunt
Post by grunt on May 27, 2010 20:54:06 GMT 1
you could always run a slightly larger pitch chain and sprocket d.i.d one be here tomorrow then i can get back out on it as i didnt want to risk it snapping as it wouldnt have taken alot
grunt
Post by grunt on May 28, 2010 23:40:05 GMT 1
fitted much better than the last one its 16-46 my last one was 16 45
Post by racerd on Aug 22, 2010 0:27:30 GMT 1
you could try running a heavy dutie chain
Post by racerd on Aug 22, 2010 0:33:53 GMT 1
16/45 is the mk2/3 ratio mate....you will find it may pick up a tad quicker and top end all out revs will be higher in top gear... ;D though the 16/45 would up gear and a 16/46 would down gear, three teeth smaller on the back is the same as going 1 bigger tooth on the front and three teeth bigger on the back is one tooth smaller on the front (16/46 to 16/43 is the same as 17/46 16/46 to 16/49 is the same as 15/46
