Post by jasper2608 on May 8, 2010 11:48:14 GMT 1
ive just got hold of a rd125mk1 im going to do a full rebuild am going to have to respray the petrol tank is it going to be better to strip it back to bare metal or just flat it back and spray it as i worried if i take it back to metal i could end up with a colander instead of a fuel tank
Post by mellow on May 8, 2010 11:57:08 GMT 1
id strip it back first m8 better to find out its like a tea bag b4 u pay out to have it sprayed then have to fix it n respray
Post by jasper2608 on May 8, 2010 15:50:04 GMT 1
is it best to get it shot blasted or is that just going to blow bigger holes in it
Post by mellow on May 8, 2010 23:29:51 GMT 1
they could use a softer media like sand to remove paint
Post by jasper2608 on May 9, 2010 10:47:18 GMT 1
yeh i would do the elbow grease bit if some idiot hadnt sprayed straight over old paint and slapped it on about 2mil thick
Post by mellow on May 9, 2010 18:09:34 GMT 1
I Disagree sand.....small grit....id say sand Have a word with ur local blasters see wot they say
Post by carlow73 on May 9, 2010 20:51:19 GMT 1
nitromors is the best option and wash down with plenty of water the paint will lift in seconds where as blasting can leave pitting , i found this out the hard way
Post by carlos on May 9, 2010 23:18:41 GMT 1
I've Nitromorsed tanks, then got some course wire wool, put nitromorse on that and given it a good scrub, it helps the paint to lift!
My painter likes a bare metal tank, less likely to get reaction, and easier to get a good finish apparently!
