mk1rob
Post by mk1rob on Apr 27, 2010 18:25:42 GMT 1
hello iv been busy restoring my mk1 i had problems with a cut down piston and doggy port work lol on a previous post now iv come to put it all back together and iv noticed that its got a 26mm carb poss tzr rk00 it states on it will i have problems with this or will i be able to run on this? help would be appreciated thanks rob
Post by Norbo on Apr 29, 2010 23:15:31 GMT 1
There is no reason you cant run witha 26mm carb its only 2 mm bigger and asooming you set it up correct it should be fine . most likely put on becourse its had a tune and running a chamber of some kined no doubt .
