grunt
Post by grunt on Apr 21, 2010 19:28:28 GMT 1
this my second piston this has happened to it melts at exhaust port side and little bit breaks off then i loose my top piston ring into 3 bits and it goes into the exhaust and it doesnt score damage the barrel why the hell is this ;D temp gauge runs at half way all the time and nice ammount of smoke out the back however i run a br9iex iridum sparky could this be the problem regards grunt
Post by looey on Apr 21, 2010 19:44:04 GMT 1
Oh mate, has this just happened after your rebuild ??.
Were you running it in when it happened or where you giving it beans ?.
Post by carlos on Apr 21, 2010 20:13:31 GMT 1
What's the plug colour like?
What pistons are you using?
grunt
Post by grunt on Apr 21, 2010 21:14:46 GMT 1
well i had done 200 miles running in and didnt exactly go grannys on it haha its odd as i have had this similar problem before oh well its only a piston i suppose however wow she shifts now i done them bits to it carlos plug colour light brown as should be all i can say is i think i gonna do the full 500 miles runnning in now (boring)
grunt
Post by grunt on Apr 21, 2010 21:21:03 GMT 1
what do i i need to do if it is running lean is it in with the air screw or out forgot its been a while
Post by carlos on Apr 21, 2010 21:23:06 GMT 1
If it's running lean at full throttle it's going to be main jet size!
Post by looey on Apr 21, 2010 21:25:54 GMT 1
I would've thought it must be getting too hot or running too lean to be melting the piston at all anywhere ?.
The thing is, wherever it melts, it always ends up around the exhaust port area cos that's where everything goes obviously
Is the crown of the piston still ok ?, got any pics you can put up ?.
grunt
Post by grunt on Apr 21, 2010 21:29:36 GMT 1
its the bit right infront of the arrow on the piston about 5-6mm wide little chunk comes off in one bit everything else is spot on a,,ok
Post by carlos on Apr 21, 2010 21:34:08 GMT 1
There's no way it could be firing a tiny bit late is there?
Post by looey on Apr 21, 2010 21:35:01 GMT 1
its the bit right infront of the arrow on the piston about 5-6mm wide little chunk comes off in one bit everything else is spot on a,,ok Is it ported at all ?, sounds to me like it might be catching on the exhaust port to be breaking a bit off there ?.
grunt
Post by grunt on Apr 21, 2010 21:35:05 GMT 1
im currently running a 240 in my rd125lc carbby with a leader kit fitted
Post by carlos on Apr 21, 2010 21:40:54 GMT 1
post a pic up!
grunt
Post by grunt on Apr 21, 2010 21:46:51 GMT 1
cant as its outside and im inside ;D ;D stressed with it atm so best i leave it for time being
grunt
Post by grunt on Apr 22, 2010 11:16:23 GMT 1
spoke to a friend i gonna put a bigger pilot jet in to improve pull away and i am going to go from 240 to 250 ditch k&n and go with my foam one then run it in as i get my new gen piston tomorrow and i be back out also i going to turn oil pump up slightly and put a little cap full of 2 stroke in tank like gaz does
Post by looey on Apr 22, 2010 12:47:16 GMT 1
I'm fairly sure it won't be anything to do with oil quantity, cos if they run light on 2-stroke oil you would get heat seize pinches around the piston, normally in the 4 hot spots, you wouldn't get bits of the piston melting and breaking off through lack of oil ?.
grunt
Post by grunt on Apr 22, 2010 12:51:57 GMT 1
well oild pump is currently running standard and i have filed ports smooth and got rid of rough edges boyseen dual stage reeds head skimmed 0.5mm iridium sparkplug leader kit and foam filter with micron so i think i should turn it up abit as standard amount of oil wouldnt do engine much good with these mods gonna get a 25 pilot jet or near there instead of the 20 and might keep 240 main and tinker air screw abit ;D
Post by carlos on Apr 22, 2010 17:44:27 GMT 1
They should have a bit of a shampfer on the ports I think
grunt
Post by grunt on Apr 22, 2010 17:50:40 GMT 1
it does still have them there but from the rebore it had afew rought bits so my engine worker said file them away and 1200 wet and dry so completely smooth then it stands no chance of getting caught
grunt
Post by grunt on Apr 24, 2010 23:10:47 GMT 1
sorted it today foam filter back on twist of air screw abit and plug was spot on ,,,removed head and looked and is all good now all thats left is to run it in
Post by rd50084matt on Apr 26, 2010 9:51:21 GMT 1
Dont run extra oil in tank as it leans the mixture out more,common mis-conception that it helps,it doesnt.
Like Gaz said cooler plug on a tuned motor helps,9 instead of 8.
Good luck with it.
grunt
Post by grunt on Apr 26, 2010 17:46:24 GMT 1
been out for the last 4 days lots of miles done runs like a dream and wipped head off and looked at piston and its sorted no melting nice colour ;D
Post by tobster on Apr 27, 2010 11:37:59 GMT 1
glad you've got it sorted. sounds like it was running lean - now you've changed to a more restrictve (but better) air filter it has richened up. Can't see the pilot jet having any positive effect on your problem - more to do with part throttle running. Just to confirm all is better, do a WOT plug chop and have a real good look into the plug and not just the surface of it. White is lean = bad. Whenever you start changing the way air gets into a 2 stroke (e.g airbox mods, filter changes) you should always be checking the mixture. As said before, do not add extra oil to the fuel as it run even leaner. Premix OR oil pump, not both.
grunt
Post by grunt on Apr 27, 2010 14:20:36 GMT 1
i ditched the oil in tank idea and have just finished running it in plug is great runs as sweet as a nut ;D ;D some clown offered a swap for my 125lc for a minature hedgehog pet ;D
