grunt
Post by grunt on Apr 15, 2010 9:20:27 GMT 1
right i am going to try and invent something but firstly i need to know is the diameter on the outside clutch cover casing on a 250-350lc same as a 125lc
Post by nikfubar on Apr 15, 2010 10:04:28 GMT 1
Is it a see through clutch window ;D
grunt
Post by grunt on Apr 15, 2010 19:25:37 GMT 1
also if its easier can anybody tell me the diameter at its widest point
regards grunt
grunt
Post by grunt on Apr 18, 2010 22:30:28 GMT 1
ryt wht i was hoping was to cut the clutch round bit off a 250lc case and weld it to a 125 case so i have the bolt holes and window just to fit if you get what i mean ;D
Post by twostroker on Apr 19, 2010 19:42:58 GMT 1
it should be possable if you take the casing to a local engineer to have a recessed hole cut out so the window sits pretty flush and some holes drilled and tapped,id also have another recess machined to fit a o-ring to seal the window,should look smart on a special bike
