Post by rich3648 on Apr 14, 2010 22:02:13 GMT 1
what is recommended main jet size for a mk3 british non working power valve with a allspeed or a micron power. standard airbox fitted. also if i open up power valve fully what is best set up with scrockets,filter and pipe to maximise performance.i heard you lose bottom end power if fully opened.any advise welcome. also im taking bike to ibiza to use this summer so any advice for running in hot temps. cheers
Post by carlos on Apr 16, 2010 7:41:31 GMT 1
As for hot temps, make sure you get the jetting spot on! It may also be possible to fit a cooling fan to the back of the radiator to assist with cooling, maybe on some sort of manual switch?
Post by rich3648 on Apr 19, 2010 21:37:56 GMT 1
just a quick question as lost my haynes manual.what is standard jet for mk3 125 lc?
Post by stev04 on May 1, 2010 23:37:22 GMT 1
it says in the manual that for the 10w is 155 and 12w is 195 standard
Post by stev04 on May 2, 2010 23:57:56 GMT 1
but MK3 is 190
