Post by nomoreheros on Apr 21, 2024 10:16:21 GMT 1
Hi guys...I'm just in the middle of my first engine rebuild....can I ask if these alloy plugs are really necessarily?.... I'm guessing not.
Post by yamman1066 on Apr 21, 2024 10:19:34 GMT 1
yes ,will leak oil if not there
Post by jon on Apr 21, 2024 10:19:43 GMT 1
Absolutely necessary. They seal the cases after boring both ends for the shafts.
You probably by the sounds of it never new they were fitted to you cases?
Post by nomoreheros on Apr 21, 2024 10:34:01 GMT 1
yes ,will leak oil if not there Never thought of that...Cheers Yamman
Post by nomoreheros on Apr 21, 2024 10:36:25 GMT 1
Absolutely necessary. They seal the cases after boring both ends for the shafts. You probably by the sounds of it never new they were fitted to you cases? Jon You're right Jon... wasn't any fitted when I stripped the engine
Post by nomoreheros on Apr 21, 2024 10:50:08 GMT 1
I presume they just tap in?
Post by jon on Apr 21, 2024 10:55:57 GMT 1
I presume they just tap in? Yes. In fact sometimes the originals need a little tap after vapour blasting. Never had to fit new ones, but Iād be tempted to use a bit of locktite. Jon
Post by nomoreheros on Apr 21, 2024 12:00:01 GMT 1
Looking back I can't believe I asked this question...it's pretty obvious... thick as f**k š
Post by urbantangleweed on Apr 21, 2024 12:09:03 GMT 1
I presume they just tap in? I tap them out, clean up the plugs and the holes, smear the plug edge with Threebond case sealant and tap them back in.
