Post by tippy on Apr 30, 2024 7:51:05 GMT 1
Found a video on you tube that explained it perfectly! Thank you for your help chaps.
Post by muttsnuts on Apr 30, 2024 8:32:43 GMT 1
set the pulses to 0.5, the instructions aren't the best, ah, see you got it sorted.......
Post by JonW on Apr 30, 2024 13:45:28 GMT 1
Always some kind of setting in the instructions...
Well done for sorting it.
Post by crogthomas on May 13, 2024 17:06:56 GMT 1
Does anyone have a internal wiring diagram for the koso dashboard unit(s)? There are a couple of different ways that the oil level light could be made to work with the standard Yamaha sender unit, but which one is best would depend on how the built-in lamp test works.
Post by crogthomas on May 16, 2024 16:23:39 GMT 1
Koso clocks, got round it by robbing a level sensor off an Aprilia and swapping it over! Is the Aprilia sender the same diameter, length and plug as the Yamaha part? If so, that sounds like a good solution. Which model was it from? If you wanted to get the Yamaha sender working, I think I have a method that would work. Let me know.
