avb
andys vapour blasting
Post by avb on Apr 14, 2024 13:34:58 GMT 1
Now I've sorted the rear brake out Its on to pv controller. I've got the airbox fitted. LC frame is it possible to mount a pv controller any where or have got to remove airbox and fit there
Post by dusty350 on Apr 14, 2024 13:56:04 GMT 1
Hi Andy It's a pita on an Lc if my experience is anything to go by !If I were doing it again I would buy the Zeel box of tricks that combines the Pv controller with the ignition. Only one box instead of 2 and you get to keep the airbox π
π
Post by urbantangleweed on Apr 14, 2024 14:02:16 GMT 1
Like Dusty says, Zeeltronic is really the way to go, one box and fully programmable ignition and PV action. A PCDI10VT is the one you want and reedx on here 3D prints a fabulous mounting box for it.
avb
Post by avb on Apr 14, 2024 14:13:14 GMT 1
I've got a ignitec on the bike I should have said mountings for the servo
Post by stusco on Apr 14, 2024 14:36:38 GMT 1
Thats the spot in your photo you can weld a bracket on or make one that clamps somehow
avb
Post by avb on Apr 14, 2024 14:40:33 GMT 1
Thats what I thought. Theres a lot of electrickery gotta fit in there
Post by jessy03 on Apr 14, 2024 15:03:37 GMT 1
Took a screenshot of this a few years back.
avb
Post by avb on Apr 14, 2024 16:06:49 GMT 1
Just need to bend and find where it goes
Post by jessy03 on Apr 14, 2024 16:48:05 GMT 1
Take your coil off, sits in there π
Post by stusco on Apr 14, 2024 17:15:40 GMT 1
Thats what I thought. Theres a lot of electrickery gotta fit in there Mine fits ok ,there is a few plugs to work around but you donβt see them anyway mine was welded on before building the bike ,that bracket looks good provided the cables reach mine just make it and the are standard length from Norbo ,you can get them made I believe
avb
Post by avb on Apr 14, 2024 19:44:30 GMT 1
Fitted great a gentle tap got it in Ii it rightwards round as 8n pvs facing this side
Post by urbantangleweed on Apr 14, 2024 21:41:35 GMT 1
You can of course fit the servo wherever it sits best and get Venhill to make you custom powervalve cables to suit. I did that for MT2, they arrived in a couple of weeks and were spot on.
Post by JonW on Apr 15, 2024 0:14:06 GMT 1
The servo is easy as has been shown, the controller is always hard as the LC has little room.
Strip a PV loom from an old loom (its separate) and then you can see where you can find a space. I went with under the seat mount and above the shock, but its not ideal tho it is neat.
