Post by Jona on Apr 11, 2024 12:21:16 GMT 1
Anyone know where I can get the clevis pin for the bottom hinge on the bikini fairing ? Cant seem to find one anywhere
Post by crogthomas on Apr 11, 2024 13:26:33 GMT 1
Is this for the YPVS LC2? It looks like a fairly standard clevis pin to me. Measure up and order on ebay?
Post by shaunthe2nd on Apr 11, 2024 13:31:28 GMT 1
I made one. Easy enough to do. Buy a short rod of correct diameter steel. I think I used a mecanno bit from memory! Heat one end and hammer a 'head' onto it. Measure correct length, cut to size, and drill small hole at the other end for the P clip.
Post by Jona on Apr 11, 2024 17:49:26 GMT 1
I made one. Easy enough to do. Buy a short rod of correct diameter steel. I think I used a mecanno bit from memory! Heat one end and hammer a 'head' onto it. Measure correct length, cut to size, and drill small hole at the other end for the P clip. Yeah I did. You would be amazed that there is only one seller in China that does 4mm by 60mm 😁
Post by Jona on Apr 11, 2024 17:50:29 GMT 1
I made one. Easy enough to do. Buy a short rod of correct diameter steel. I think I used a mecanno bit from memory! Heat one end and hammer a 'head' onto it. Measure correct length, cut to size, and drill small hole at the other end for the P clip. I’d spend a load of time and f*** it up 😂
Post by LC_BOTT on Apr 11, 2024 20:46:47 GMT 1
Post by JonW on Apr 12, 2024 14:22:05 GMT 1
6 inch nail... well 60mm at least...
I jest (a bit, but a nail has the head already formed, just drill the hole and cut the pointy bit off) but I once bought a bike (the F1 I still have) held together with long nails for the ebay pics and was still like a porcupine when I collected it.
Post by Jona on Apr 13, 2024 18:30:58 GMT 1
6 inch nail... well 60mm at least... I jest (a bit, but a nail has the head already formed, just drill the hole and cut the pointy bit off) but I once bought a bike (the F1 I still have) held together with long nails for the ebay pics and was still like a porcupine when I collected it. I have ordered a couple from China. Only place that did the length 😁
Post by shaunthe2nd on Apr 14, 2024 12:16:48 GMT 1
I was hanging an internal door yesterday and looks like the hinge pin would be a good starting point to make one if you have an old hinge.
Post by reedpete on Apr 14, 2024 18:37:15 GMT 1
For diy, it’s easier to just find piece of rod the correct diameter and then put a washer and split pin both ends… easier to drill holes than make nice flat heads…
Post by Shytalk on Apr 16, 2024 13:58:47 GMT 1
91701-05060, clevis pin
Mainly unavailable, but still possible to get in a couple of places, post will be more than the parts value for sure, google it and see.
G
Post by G on Apr 16, 2024 19:30:42 GMT 1
Anyone know where I can get the clevis pin for the bottom hinge on the bikini fairing ? Cant seem to find one anywhere Had the same issue. Get some of these amzn.eu/d/3vM7euQand then use 2 nuts to secure (2nd locks in place) Does the job 👍
