Post by 4l04ever on Apr 1, 2024 17:06:18 GMT 1
Any suggestions for which oil and how much? Just stick with OEM or is there a better option???
Post by linx on Apr 1, 2024 17:16:08 GMT 1
I'd use 10w fork oil if you are using standard springs
Post by chrisg on Apr 1, 2024 17:37:36 GMT 1
15 weight and 160ml now i,m no longer 9st, JMO. I put a 20mm spacer in, to pre load the spring.
Post by urbantangleweed on Apr 1, 2024 17:51:35 GMT 1
I mix a litre each of 10 and 15 weight and use the resulting 12.5 weight.
Post by linx on Apr 1, 2024 18:08:49 GMT 1
I mix a litre each of 10 and 15 weight and use the resulting 12.5 weight. Yes I've done that too. 15wt with Hagon springs.
Post by wallcraft on Apr 1, 2024 22:15:37 GMT 1
15wt with wurth stock lc springs, 20mm pre-load, 90mm air gap👍
