Post by simonlc on Apr 1, 2024 11:02:35 GMT 1
Just fitted 1WT bottom end in my LC and obviously the clutch arm operation is in a different place but LC cable end are correct but noticing inner cable too long . Looked at later cable but noticed it has 90 degree bend at one end which won’t work . What have people used ?
Post by midlifecrisisrd on Apr 1, 2024 13:37:17 GMT 1
The 51l prefixed cable has no bend
Post by midlifecrisisrd on Apr 1, 2024 13:39:50 GMT 1
Sorry, put 1ar on instead of 51L
Post by simonlc on Apr 1, 2024 18:18:56 GMT 1
Cheers Steve
Post by JonW on Apr 3, 2024 5:12:32 GMT 1
It sounds like you're dealing with a tricky situation! When encountering a different t mobile phone clutch arm operation after fitting a 1WT bottom end in your LC, finding the right cable length and bend can be challenging. Some options people have used include customizing cables or adapters, seeking aftermarket solutions, or consulting with fellow enthusiasts or mechanics for suggestions. It's a matter of trial and error, but with some ingenuity, you'll likely find a suitable solution to get your setup running smoothly again. Sounds like AI BS...
Post by dusty350 on Apr 3, 2024 6:45:58 GMT 1
Booted !!
Post by urbantangleweed on Apr 3, 2024 6:55:35 GMT 1
It sounds like you're dealing with a tricky situation! When encountering a different t mobile phone clutch arm operation after fitting a 1WT bottom end in your LC, finding the right cable length and bend can be challenging. Some options people have used include customizing cables or adapters, seeking aftermarket solutions, or consulting with fellow enthusiasts or mechanics for suggestions. It's a matter of trial and error, but with some ingenuity, you'll likely find a suitable solution to get your setup running smoothly again. Sounds like AI BS... She sounds genuine to me, well, in a faithful and devoted "Thai girlfriend" kinda way.....
Post by jon on Apr 4, 2024 19:58:43 GMT 1
Has anyone tried the Japanese made TSK 51L clutch cable or it a genuine one the only choice?
Post by midlifecrisisrd on Apr 4, 2024 20:43:58 GMT 1
Has anyone tried the Japanese made TSK 51L clutch cable or it a genuine one the only choice? Jon I've never seen a pattern clutch cable that has the Teflon liner Typically the genuine one is cheaper from wemoto, handy if you need some other exotic bits Steve
Post by jon on Apr 4, 2024 21:00:53 GMT 1
Has anyone tried the Japanese made TSK 51L clutch cable or it a genuine one the only choice? Jon I've never seen a pattern clutch cable that has the Teflon liner Typically the genuine one is cheaper from wemoto, handy if you need some other exotic bits Steve The photos look like they do? I have asked the seller. Jon
Post by midlifecrisisrd on Apr 4, 2024 21:30:09 GMT 1
Worth a try 👍
Post by JonW on Apr 4, 2024 23:26:51 GMT 1
Has anyone tried the Japanese made TSK 51L clutch cable or it a genuine one the only choice? Jon The 51L is really cheap from Yam if you shop around...
Post by simonlc on Apr 5, 2024 20:06:04 GMT 1
All sorted cheers Steve’s advice spot on👍. Now bloody throttle cables as in post above 🤦♂️
Post by urbantangleweed on Apr 7, 2024 8:14:46 GMT 1
All those listings state "last one" so they're probably out of stock and put a silly price in so it doesn't get bought but the listing stays live. Once they have more in stock, they'll change the price back to what it should be.
Post by jon on Apr 7, 2024 8:36:43 GMT 1
All those lidstings state "last one" so they're probably out of stock and put a silly price in so it doesn't get bought but the listing stays live. Once they have more in stock, they'll change the price back to what it should be. That makes sense. Jon
Post by urbantangleweed on Apr 12, 2024 7:40:19 GMT 1
Has anyone tried the Japanese made TSK 51L clutch cable or it a genuine one the only choice? Jon I've never seen a pattern clutch cable that has the Teflon liner Typically the genuine one is cheaper from wemoto, handy if you need some other exotic bits Steve In the interest of curiosity, I ordered a Hi-Lex/TSK 51L clutch cable. It does have some sort of liner on the boden cable. It was £14.99 delivered from the 'bay.
