Post by Jona on Mar 28, 2024 12:22:31 GMT 1
Hi All. Hope you are all well.
For the last year, I have been restoring an LC2, or so i thought and believed. I had never took any notice of the numbers on the engine and frame, apart from the fact that they matched.
A friend originally bought the bike as a rough but running example a few years ago and it was dressed as an LC2 complete with screen etc. The bike was black without any decals. It had different forks and front mudguard but just thought these had been changed at some point in its life. I bought the bike off him 18 months ago and proceeded to restore it. I did leave the forks as they were and realized that the calipers were also different when the seal kit and pads I ordered didn’t fit. I still thought nothing of it and just continued as planned.
Fast forward to today, when for some reason I looked at the numbers which start 080 and realise that if the table I am looking at is correct, that this is a RD350 N1 ! Hopefully you guys will confirm this
It will then explain the black colour, front forks and calipers I believe.
Fingers crossed !
Post by Yogi on Mar 28, 2024 17:37:03 GMT 1
Yep 080 is a Uk n1. Hence the later front end and rear swingarm
There’s quite a lot of difference's including the loom,switchgear wiring,cdi, ignition,exhausts,clocks light brackets and the horn mounted under the tank Probably more I’ve forgotten 😵💫
Matt🐻🐶🐶
Post by Jona on Mar 28, 2024 18:07:04 GMT 1
Yep 080 is a Uk n1. Hence the later front end and rear swingarm There’s quite a lot of difference's including the loom,switchgear wiring,cdi, ignition,exhausts,clocks light brackets and the horn mounted under the tank Probably more I’ve forgotten 😵💫 Matt🐻🐶🐶 Thanks Matt. Made my day !! Even though I now have to swap some things. I know I have the right forks, calipers, front mudguard. I also know the clocks & headlight brackets are incorrect but I have no idea if the switchgear or swing arm are correct or not and as for the horn mounted under the tank 🤔 Just a shame there are lots of parts like loom I have bought for the bike (LC2) but I guess they will all resell Is there anywhere I can find out whether it was black or white originally ?
Post by Yogi on Mar 28, 2024 18:17:07 GMT 1
If the switchgear connects under the tank there correct, the swingarm should be box section with internal adjusters As for original colour I’m not sure,maybe midlifecrisis will know Here’s an N1 I did that may help. rdlccrazy.proboards.com/thread/37587/black-n1-rebuildMatt
Post by midlifecrisisrd on Mar 28, 2024 18:26:19 GMT 1
Highly likely if a UK bike it would be most likely white
Surprised at 31k-080 number though
I had an 86 on a D and it was 31k-078
If its actually 31k-008 then an LC2
An N should have side fairing brackets on the frame beside the little plastic infills
Post by midlifecrisisrd on Mar 28, 2024 18:27:45 GMT 1
I thought all the UK ones were 077 and 078
Ones starting 085 were German 31w restricted models
Post by Jona on Mar 28, 2024 19:09:42 GMT 1
It was this list i used which shows 080 as a European N1. It also had the forks and front mudguard on. Lots of parts were missing but have collected everything as an LC2 as thats what i believed it was IMG_0319 by Steve Jones, on Flickr
Post by Jona on Mar 28, 2024 19:12:38 GMT 1
This is the bike currently. Not sure if you can tell if the swingarm is for an N1 IMG_0309 by Steve Jones, on Flickr
Post by stusco on Mar 28, 2024 19:19:47 GMT 1
It doesn’t look like yogi’s
Post by stusco on Mar 28, 2024 19:21:55 GMT 1
Post by dusty350 on Mar 28, 2024 19:23:53 GMT 1
That's an early swingarm. Later arms had the chain adjusters inside the box section
Post by Jona on Mar 28, 2024 19:31:04 GMT 1
It doesn’t look like yogi’s Nope, it doesn`t look like that
Post by Jona on Mar 28, 2024 20:07:12 GMT 1
If the switchgear connects under the tank there correct, the swingarm should be box section with internal adjusters As for original colour I’m not sure,maybe midlifecrisis will know Here’s an N1 I did that may help. rdlccrazy.proboards.com/thread/37587/black-n1-rebuildMatt Great build ! Looks fantastic
Post by Jona on Mar 28, 2024 20:24:40 GMT 1
Highly likely if a UK bike it would be most likely white Surprised at 31k-080 number though I had an 86 on a D and it was 31k-078 If its actually 31k-008 then an LC2 An N should have side fairing brackets on the frame beside the little plastic infills Steve On the list I showed, all LC2 both European and German ended at 48000 The 080 shows as a European N
Post by jessy03 on Mar 28, 2024 20:32:57 GMT 1
That’s an LC2 swingarm 👍
Post by Jona on Mar 28, 2024 20:48:16 GMT 1
Yeah someone already said it’s not the correct one 😁
Post by midlifecrisisrd on Mar 28, 2024 20:49:19 GMT 1
That's an LC2 frame and swing arm
It has either complete later forks or just the lowers hence the different muddy and calipers
Another indicator will be the cdi. Lc2 is 29k50, n1 is 52y50
Post by midlifecrisisrd on Mar 28, 2024 20:53:36 GMT 1
31k-080 does go with N model as per the vin list, I've just never seen one above 078
Frame has no fairing mounts as per LC2 and the belly pan mounts are Lc2
What reg letter is it on?
Post by midlifecrisisrd on Mar 28, 2024 20:59:02 GMT 1
I'd also say that list of vins is the allocated range
It says the F goes up to 077000. You will never see one that high, they were mostly 053,054,055 etc
Post by midlifecrisisrd on Mar 28, 2024 21:09:33 GMT 1
Also just looked on your build thread
The N and F used the same frame so as well as the side fairing brackets it had a headstock bracket and a different set of rad cover brackets
Your frame does not have any of the N/F brackets
Also the ignition steering lock tab is right at the top of the headstock like an LC2, the N/F was about an inch lower
N/F UK bikes also has the separate steering lock on the headstock like Euro bikes
Post by Jona on Mar 28, 2024 21:18:57 GMT 1
That's an LC2 frame and swing arm It has either complete later forks or just the lowers hence the different muddy and calipers Another indicator will be the cdi. Lc2 is 29k50, n1 is 52y50 Steve Thanks Steve. I will check it all tomorrow
Post by Jona on Mar 28, 2024 21:21:21 GMT 1
Also just looked on your build thread The N and F used the same frame so as well as the side fairing brackets it had a headstock bracket and a different set of rad cover brackets Your frame does not have any of the N/F brackets Also the ignition steering lock tab is right at the top of the headstock like an LC2, the N/F was about an inch lower N/F UK bikes also has the separate steering lock on the headstock like Euro bikes Steve So it is looking like an LC2 then 😁 Just funny number that doesn’t tie in with any LC number on the list 🤔
Post by Jona on Mar 28, 2024 21:22:41 GMT 1
That's an LC2 frame and swing arm It has either complete later forks or just the lowers hence the different muddy and calipers Another indicator will be the cdi. Lc2 is 29k50, n1 is 52y50 Steve Thanks Steve. I will check it all tomorrow The forks have the air valves on the top of them
Post by Jona on Mar 28, 2024 21:26:36 GMT 1
31k-080 does go with N model as per the vin list, I've just never seen one above 078 Frame has no fairing mounts as per LC2 and the belly pan mounts are Lc2 What reg letter is it on? Steve It’s on a “B” 85 Thanks for all your great answers. Very knowledgeable 😁 I will carry on with the LC ll build 😁😁 but with later forks muddy and calipers 😂😂
Post by Jona on Mar 28, 2024 22:52:57 GMT 1
All Gravest apologies ! I need to go to Specsavers ! The number is 030 not 080 At least it gave you guys the platform to show your extensive knowledge 😁
Thanks again to all who helped
Post by midlifecrisisrd on Mar 28, 2024 23:03:13 GMT 1
Easily done
Bike will be an 84 model so would originally have been the later white tank with red top and blue pinstripe like the F1
Post by Jona on Mar 28, 2024 23:35:05 GMT 1
🤣🤣🤣🤣🤣 Easily done Bike will be an 84 model so would originally have been the later white tank with red top and blue pinstripe like the F1 Steve I’m actually going for the Kenny Roberts colours 😁 not to everyone’s taste but I always fancied it
freddie19
Member is Online
Post by freddie19 on Mar 29, 2024 5:56:44 GMT 1
🤣🤣🤣🤣🤣 Easily done Bike will be an 84 model so would originally have been the later white tank with red top and blue pinstripe like the F1 Steve I’m actually going for the Kenny Roberts colours 😁 not to everyone’s taste but I always fancied it Not to everyone's taste, you what, I'm with you...... definitely the best paint scheme for the LC2/ RZ.😁 Yamaha missed a trick by not selling the KR model in the UK, if they had they'd have sold thousands of them especially when back in the early 80's King Kenny was on top of the world!.......then again, I am a bit biased!😂
Post by Jona on Mar 29, 2024 9:49:03 GMT 1
I’m actually going for the Kenny Roberts colours 😁 not to everyone’s taste but I always fancied it Not to everyone's taste, you what, I'm with you...... definitely the best paint scheme for the LC2/ RZ.😁 Yamaha missed a trick by not selling the KR model in the UK, if they had they'd have sold thousands of them especially when back in the early 80's King Kenny was on top of the world!.......then again, I am a bit biased!😂 Lovely looking thing ! Hope mine looks as good ! 😁
Post by Jona on Mar 29, 2024 10:12:40 GMT 1
That's an LC2 frame and swing arm It has either complete later forks or just the lowers hence the different muddy and calipers Another indicator will be the cdi. Lc2 is 29k50, n1 is 52y50 Steve Hi again. The CDI is actually 1UA-50. Will that be any detriment at all ?
