Post by Bozzy on Mar 26, 2024 14:46:57 GMT 1
Hi, Has anyone used the Mad Biker inner billet PV bushes with the integrated bolt fixing?
Removed mine and everything is solid but wonder if above is worth the spend and just go for the thinker retainers as loads of other bits to get.... I also like the billet joint link as well.
Finding it starts costing lots when looking at all of the mods/upgrades about during a rebuild
Thanks Bozzy
PV bushes
Mar 26, 2024 20:16:06 GMT 1
via mobile
Post by huggy76 on Mar 26, 2024 20:16:06 GMT 1
Bozzy, I too have been looking at these as they seem like a good idea for a known weak point. Interested to see what others have to say. I will also probably be looking at some mutts nutts valves but just waiting until I get my engine stripped to see that I definitely need them. 👍
Post by jessy03 on Mar 26, 2024 20:31:27 GMT 1
I have some fitted, but not used the engine, like you say potential fix for a weak spot, but saying that my current engine runs the standard bushes, been fine for the last 7-8 Years.
Post by muttsnuts on Mar 26, 2024 20:41:41 GMT 1
I looked at making some like that, but the extra cost of doing it wasn't justified compared to just having some slightly thicker half moon plates made, the stock Yamaha ones are a tad too thin, so I had some made that are just that bit thicker and stop the bush rotating (which is what knackers them), I don't have them listed on my website as I can't be arsed with people asking me to sell 2 plates, its not worth my time, but I supply them with the valves and bushes if people ask me
Post by JonW on Mar 27, 2024 0:15:08 GMT 1
Im in 2 minds about these... yes, they wont move and are new etc etc
.... but... the 500 has end caps with 1 bolt hole like this and they break off, leaving you with a different problem.
jimmyg
PV bushes
Mar 27, 2024 0:51:18 GMT 1
via mobile
Post by jimmyg on Mar 27, 2024 0:51:18 GMT 1
Did sidney82 not use some on his brothers power valve build?
Post by Bozzy on Mar 27, 2024 11:49:17 GMT 1
Im in 2 minds about these... yes, they wont move and are new etc etc .... but... the 500 has end caps with 1 bolt hole like this and they break off, leaving you with a different problem. Interesting one having second thoughts now I expect the original retainers have slight flex where these are solid fixing... might be over thinking it adding another potential issue who knows... the bushes took some getting out and taking account of the mileage and years our bikes have done with original thin retainers thinking that upgrading them to the thinker retainers feels now more like a better half way house
PV bushes
Mar 27, 2024 13:36:20 GMT 1
via mobile
Post by headcoats on Mar 27, 2024 13:36:20 GMT 1
I use the orange seals and use a bit of silicone to hold them and had zero issues
Post by Bozzy on Mar 27, 2024 20:27:12 GMT 1
I use the orange seals and use a bit of silicone to hold them and had zero issues I was wondering if to use a bit of clear silicone gasket sealant around the bushes when fitting... did you put some on the outer surface of the actual orange inner seal?
PV bushes
Mar 27, 2024 20:44:29 GMT 1
via mobile
Post by headcoats on Mar 27, 2024 20:44:29 GMT 1
As you push them in you will get silicone on the orange seals
Post by muttsnuts on Mar 27, 2024 21:11:19 GMT 1
I have some slightly oversize "O" rings that go on the bush housing, this takes out any wear and makes them a proper snug fit - b*****ds to push in TBH, but makes them solid and they stay put, just use plenty of rubber grease on them when fitting
I can 4 of them for £6 + postage
Post by urbantangleweed on Mar 28, 2024 8:47:52 GMT 1
I will also probably be looking at some mutts nutts valves but just waiting until I get my engine stripped to see that I definitely need them. 👍 I fitted a pair of Mutts Nuts valves in MT2's engine and they are excellent. OK, they're a bit dearer than others, but for good reason.
Post by urbantangleweed on Mar 28, 2024 8:48:42 GMT 1
I have some slightly oversize "O" rings that go on the bush housing, this takes out any wear and makes them a proper snug fit - b*****ds to push in TBH, but makes them solid and they stay put, just use plenty of rubber grease on them when fitting I can 4 of them for £6 + postage PM'd you Dave, I'll have a set of them to try.
Post by Bozzy on Mar 28, 2024 10:55:37 GMT 1
+1 Dave PM'd you
