ronnie2735
RD 250 LC 4L1 1981 Enjoyer
Post by ronnie2735 on Mar 26, 2024 13:01:03 GMT 1
Hello
again a problem unfortunately
i was riding uphill suddently there was a scraping sound then was there this spring at the right side and the cable was able to be pulled out a bit
is this norma and what is this cable made for?
the images:
thanks for replys
greetings ronnie
Post by JonW on Mar 26, 2024 13:17:10 GMT 1
Its the oil pump part of the throttle cable...
A copy version of a throttle cable, sadly, hence likely why you have slack... been proven lots of times (search the forum) to not be the right length.
...plus the clip is missing that stops it moving upwards and hold the cable captive. Have a look at the parts book.
Oh and the scraping sound isnt this IMHO... need to look elsewhere I think.
ronnie2735
Post by ronnie2735 on Mar 26, 2024 13:30:09 GMT 1
Its the oil pump part of the throttle cable... A copy version of a throttle cable, sadly, hence likely why you have slack... been proven lots of times (search the forum) to not be the right length. ...plus the clip is missing that stops it moving upwards and hold the cable captive. Have a look at the parts book. Oh and the scraping sound isnt this IMHO... need to look elsewhere I think. is this something risky to drive with or woud you replace it instantly?
Post by shaunthe2nd on Mar 26, 2024 16:03:39 GMT 1
I would be checking it's connected properly to the oil pump and delivering oil correctly to the carbs. Hope the scaping isn't the sound of dry pistons sliding up and down the barrels.
Post by chrisg on Mar 26, 2024 21:00:46 GMT 1
Are you refering to the spring around the oil pimp cable? I always thought they were heat protection for the cable.
Post by JonW on Mar 27, 2024 1:54:45 GMT 1
Chris is right that is what the spring is for... but it wont be making the noise.
As Shaun rightly points out you should check the adjustment on the cable for your oil pump... BEFORE you ride it again.
I would also be pricing up an OEM cable if the one on yours is not correct for oil pump length. Read the threads on here about it first, Im not across the fixes as I never buy a non OEM LC throttle cable as its a false economy on an LC IMHO - I believe that the expense is worth it, same with all the cables.
Listen again to the noise. You need to track this down BEFORE you ride again.
Basic tests time... Is it when the engine is running? bike rolling? engine off bike rolling? could be the clutch/flywheel, could be the speedo/tacho/cable, could be the pistons... could be so many things... need to narrow the noise down to a location.
ronnie2735
Post by ronnie2735 on Mar 27, 2024 8:23:18 GMT 1
Chris is right that is what the spring is for... but it wont be making the noise. As Shaun rightly points out you should check the adjustment on the cable for your oil pump... BEFORE you ride it again. I would also be pricing up an OEM cable if the one on yours is not correct for oil pump length. Read the threads on here about it first, Im not across the fixes as I never buy a non OEM LC throttle cable as its a false economy on an LC IMHO - I believe that the expense is worth it, same with all the cables. Listen again to the noise. You need to track this down BEFORE you ride again. Basic tests time... Is it when the engine is running? bike rolling? engine off bike rolling? could be the clutch/flywheel, could be the speedo/tacho/cable, could be the pistons... could be so many things... need to narrow the noise down to a location. thank you very much for the advice will do that
where the oilpump is is this covered by oil itself or can you the the cover of without drowining the oil?
thank you for the advice!
greetings ronnie
Post by dusty350 on Mar 27, 2024 8:31:30 GMT 1
No oil in the small case
ronnie2735
Post by ronnie2735 on Mar 27, 2024 8:52:15 GMT 1
No oil in the small case nice
Post by JonW on Mar 27, 2024 12:44:07 GMT 1
ronnie2735
Post by ronnie2735 on Mar 31, 2024 10:48:30 GMT 1
One is one the way Idk why but i coud only buy the phisical one Is there a gas cable you woud recomend that woeked good in the Past Greetngs ronnie
Post by JonW on Mar 31, 2024 12:46:23 GMT 1
Greetngs ronnie Yes the original one from Yamaha. Its not cheap but your LC is worth it.
