ronnie2735
RD 250 LC 4L1 1981 Enjoyer
Post by ronnie2735 on Mar 21, 2024 18:14:13 GMT 1
Oi mates its again time for repairs
My cluchcable snaped of a few wires so the cluch dint disconecct all the way
I ordered a new one it arives the 27 th
But i dont know how to mount it at the engine side. I removed the plastic cover at the left and saw a hole with a screw
How is the cluch mounted at the engine and how can you replace it?
Thanks for awnsers Greetings ronnie
I will post some pictures in a minute
ronnie2735
Post by ronnie2735 on Mar 21, 2024 18:30:58 GMT 1
the brocken cable
Where it is mounted and the screw
Post by beardy on Mar 21, 2024 18:33:27 GMT 1
Remove the gear lever clamp on the gear shaft. Then remove the whole left case. By looking at the old cable you will see how the new one fits. Worth buying a Haynes manual 👍🏻
Post by 4l04ever on Mar 21, 2024 19:06:07 GMT 1
Hopefully, you got an OEM Yamaha cable as all the after-market ones cause a stiff clutch lever.
ronnie2735
Post by ronnie2735 on Mar 21, 2024 21:18:05 GMT 1
Hopefully, you got an OEM Yamaha cable as all the after-market ones cause a stiff clutch lever. I baught a cheap one Do you know a good cable you trust? And in the half of the engine do you have to take the engine out of the bike or can you repair this without taking the enging out Also is that a chuch where there is oil in it or without? Its a bit of a bummer that you have to take the engine apart for a cluch cable Greetings ronnie
Post by midlifecrisisrd on Mar 21, 2024 21:30:46 GMT 1
The left hand case only covers the sprocket and flywheel, no oil in there and no need for the engine to come out
Clutch mechanism is bolted into the left case
Gen Yam cable only and not that expensive
ronnie2735
Post by ronnie2735 on Mar 21, 2024 21:39:14 GMT 1
The left hand case only covers the sprocket and flywheel, no oil in there and no need for the engine to come out Clutch mechanism is bolted into the left case Gen Yam cable only and not that expensive Steve yambits.co.uk/rd250lc-clutch-cable-p-667.htmlIs this a good one Doe some one maby a have a link to a geniuene one? Tanks alot for the help Ronnie
Post by shaunthe2nd on Mar 21, 2024 22:09:03 GMT 1
Ronnie, it's worth buying a Haynes manual, and whilst not 100% correct it covers most things well like this. If you can afford a genuine cable, buy that as can save a lot of time, otherwise but best you can. Once you have changed it, hopefully you will be motivated to try other maintenance tasks, and slowly you will build up an expertise. Luckily these bikes are quite basic and can be maintained and rebuilt by those with some mechanical sympathy and keenness to learn. Good luck with it, and enjoy your ride outs.
ronnie2735
Post by ronnie2735 on Mar 21, 2024 22:25:19 GMT 1
Thanks for the tipps Ronnie
Post by midlifecrisisrd on Mar 21, 2024 22:51:16 GMT 1
Post by shaunthe2nd on Mar 21, 2024 23:00:03 GMT 1
^^^^ that one. Its not worth saving a tenner on a crappy copy unless you absolutely know what you are buying.
Post by chrisg on Mar 22, 2024 0:03:19 GMT 1
Hopefully, you got an OEM Yamaha cable as all the after-market ones cause a stiff clutch lever. +1 I couldn't believe the difference between a pattern cable and Yamaha. Well worth it. Fowlers, bit more expensive than ebay one. www.fowlersparts.co.uk/parts/view/4L0-26335-00
Post by abar121 on Mar 22, 2024 10:06:54 GMT 1
How does that compare to Norbo's Jap cable?
