Post by steve99 on Mar 20, 2024 17:06:43 GMT 1
Hi all
Does the battery on a ypvs have to be fully charged or will it start on a flat battery like the old LC’s
I ask because my RD350F2 will not fire up. Was ok when bedded down for winter but I think the battery is on its way out
cheers Steve
Post by stusco on Mar 20, 2024 17:17:04 GMT 1
It should start on a standard cdi if it has a zeel it needs the battery i think
Post by steve99 on Mar 20, 2024 17:38:59 GMT 1
The power valves are cycling- just
Panel light glow brighter when I kick it over but it will not start
Post by stusco on Mar 20, 2024 18:37:03 GMT 1
Does it spark?
Post by midlifecrisisrd on Mar 20, 2024 19:22:28 GMT 1
Should start OK
Check for a spark first.
May have passed fuel into the crankcases while standing and flooded it
Post by abar121 on Mar 20, 2024 20:01:32 GMT 1
Check the pilot jets, assuming there's fuel and spark.
Post by Chewie01 on Mar 21, 2024 12:39:10 GMT 1
When I got my F2 out the shed after its winter hibernation the battery was stone dead. A few kicks and it fire up without any issue.
Post by steve99 on Mar 21, 2024 22:03:16 GMT 1
Had spark and fuel but would not start. In the end I got it running kicking over with full throttle and it eventually started to fire and then started. Once running then ran and started perfect. Head scratching time?
Post by 84rzrider on Mar 21, 2024 22:36:59 GMT 1
In my experience if you had to hold it wide open to get it to fire it was likey flooded. Make sure your fuel valve is functioning correctly and not on all the time.
Post by midlifecrisisrd on Mar 21, 2024 22:53:10 GMT 1
Yep, flooded
