Post by steve99 on Mar 15, 2024 9:39:24 GMT 1
Hi all, my RD350LC must have been run on premix as the oil pump is missing. I want to put it back to standard. Can someone please let me have a photo of what parts are on the shaft inside the casing and how they go together
Currently I have a pump and the shaft. Nothing else
cheers Steve
Post by midlifecrisisrd on Mar 15, 2024 9:44:15 GMT 1
Here It's ypvs but the same other than the extra clip retainer tab under the circlip which is a good addition as it stops any chance of the circlip coming loose Don't forget the little thrust washer at the pump end of the drive Steve
Post by midlifecrisisrd on Mar 15, 2024 9:46:03 GMT 1
Post by steve99 on Mar 15, 2024 10:22:38 GMT 1
That’s ideal. Many thanks
Post by chrisg on Mar 15, 2024 11:01:54 GMT 1
If you dont know the condition of the pump or why it was removed i would get it refurbished. Arrow is the go to guy if your unsure.
Post by steve99 on Mar 15, 2024 15:54:49 GMT 1
The pump was on the bike but everything on the shaft had been removed. I will check the pump out before risking the engine
Post by chrisg on Mar 17, 2024 17:39:08 GMT 1
There is a thread that tells you how much oil is dispensed per 200 strokes (i think) that Arrow has contributed to. I have plumbed the oil pump in to the side casing and tank and then used a battery drill to operate it to ensure all is ok and you can check the stroke/gap that way as well.
