Post by pylwagl on Mar 13, 2024 19:33:19 GMT 1
So, I've fitted a new rear sprocket and have found the nuts do not wind all the way down. The sprocket is fully seated on the carrier, correct nuts, sprocket is Afam item. Is this usual? TIA Stu
Post by oldelsieboy on Mar 13, 2024 19:55:46 GMT 1
So, I've fitted a new rear sprocket and have found the nuts do not wind all the way down. The sprocket is fully seated on the carrier, correct nuts, sprocket is Afam item. Is this usual? TIA Stu Should be half nuts, looks like you've fitted standard size. OEB
Post by pylwagl on Mar 13, 2024 20:15:16 GMT 1
Ah, thanks, that makes sense. I don't think I'll be recommending the Yambits rear sprocket nut kit (silver) to anyone anytime soon
Post by 4l04ever on Mar 13, 2024 21:06:27 GMT 1
This is my tab washers and nuts on my number 4 build.
Post by pylwagl on Mar 14, 2024 9:33:30 GMT 1
Your studs look a little longer than mine. I'll just turn the garage upside down looking for the originals - or just get some new ones from the store on here
Post by JonW on Mar 14, 2024 13:46:43 GMT 1
So, I've fitted a new rear sprocket and have found the nuts do not wind all the way down. The sprocket is fully seated on the carrier, correct nuts, sprocket is Afam item. Is this usual? TIA Stu Ah, thanks, that makes sense. I don't think I'll be recommending the Yambits rear sprocket nut kit (silver) to anyone anytime soon Ahh...
