dex46
Post by dex46 on Mar 12, 2024 20:52:36 GMT 1
Hi all One for the hybrid builders Iโm currently picking up parts for my upcoming build will be running Rgv front and Rgv22 rear with a Metchamex I was wondering could someone share brake hose lengths for the front and rear please so I can get them knocked of the shopping list will be using straight bars. Thanks in advance Dex
Post by mouse on Mar 13, 2024 7:45:22 GMT 1
I would build it first and then work out the length you need. Every hybrid will be different, somebody may measure for you but you might be using slightly different handlebars and so the measurement wont be quite what you want, or you may position your mastercylinder differently or be using a different one altogether etc. there are a lot of variables!
HTH Mouse
Post by dusty350 on Mar 13, 2024 7:59:47 GMT 1
+1 on that Mouse I use an old braided brake line to get the length spot on. Cut an old line in half and bolt each end in place on caliper and master cylinder. Then use tubing - petrol pipe tube is ideal, and push each end of the brake line into it. Trim to suit. This will give you an adjustable means to gauge the correct length of the line, and also allow you to orientate the banjo fittings at the correct angle by twisting each part of the line in the tubing. I've found this far more accurate than a tailors tape measure, and once happy I take it to a local place where they copy the line exactly.
dex46
Post by dex46 on Mar 13, 2024 10:58:32 GMT 1
Cheers guys Iโll hang fire on that then makes sense just a thought of getting everything in place for the build before I start ๐๐ Dex
Post by lcmarky on Mar 13, 2024 13:39:49 GMT 1
Definitely hold fire & measure up when it's all together. Goodridge I think I used and they arrived pretty much next day on custom lengths..
Post by lcmarky on Mar 13, 2024 13:40:30 GMT 1
The bigger choice is the fitting geometry.
Post by jon on Mar 13, 2024 19:29:07 GMT 1
I did something similar to get the routing right. Triumph 4 pots on an F2. Ended up using CP race tech to not only get the lengths right but the torsional angles on the banjos as well as the angled bends. He said not to worry about the torsional angles as heโd leave the heat shrink un-shrunk and I could just twist them before shrink wrapping.
I will use them again as preference.
Seem to remember he said he was an ex hell employee (the little devil ๐ฟ ๐).
