Post by fordiebeer on Mar 10, 2024 15:13:04 GMT 1
f2 ypvs fitted with pwk carbs and zeeltronic ignition , only running on left side , sparks are strong both sides and carbs are clean and both fill up with fuel , just taken exhaust pipe off right side and was full of fuel ,put back together and started the bike took plug out of right side pot whilst it was running to clear crankcase of any fuel , killed the engine , put plug back in , same result , stone cold on the right pot , any ideas please guys ?
Post by midlifecrisisrd on Mar 10, 2024 15:18:08 GMT 1
Most likely still fuel in the crankcase
Not enough to throw out but enough to wet the plug
Either leave a few days with the plug out or put on welding gloves, blow torch on a spark plug, quickly fit plug and try to start
Repeat till it fires
Post by headcoats on Mar 10, 2024 15:40:44 GMT 1
Only takes a spec to block the tiny holes in pwk carbs. Have you taken the security screws out to remove the jet block and cleaned that.
I use fishing line and wd40 with the red straw to squirt through the tiny holes and if it spurts out the otherside it shows its clean. Do dame with pilot jets
