bj
Newbe
Post by bj on Mar 5, 2024 0:47:13 GMT 1
Hello, I’m refurbishing a mk1 front brake caliper. I have a seal kit but it doesn’t contain the crossover seals - the small pressure seals on the rod bolts that connect the two body half’s together. I’ve googled, but I can’t find anything the same size. One is perished, 14mm ID 16mm(or greater) OD, 2mm wide. Has anyone got a part no. Or experience replacing these seals - thanks
Rgds Bryn
Post by crogthomas on Mar 5, 2024 9:35:51 GMT 1
I had a similar problem with another type of caliper and contacted a company called powerhouse. I gave them the dimensions of the recess in the caliper and they were able to suggest a seal to fit.
robw
Post by robw on Mar 5, 2024 9:57:04 GMT 1
bj
Newbe
Post by bj on Mar 6, 2024 21:43:31 GMT 1
Thanks, I’ll give Powerhouse a go.
Post by museumman on Mar 16, 2024 21:05:49 GMT 1
You mean the MK2 caliper. I found them listed for a TZR 125 2 series and I've been supplied 2 different sizes both fractionally different to the OEM ones.
I've never seen perished ones, so your's may not be oem anyway.
