Post by nomoreheros on Feb 19, 2024 22:02:22 GMT 1
Question.....does a PV (31k) sidestand fit on a 4L0?
Post by donkeychomp on Feb 19, 2024 22:12:28 GMT 1
Pretty sure no, or not without serious modification.
Post by jon on Feb 19, 2024 22:16:24 GMT 1
From memory the stand is the same mostly dimensionally apart from the bolt hole size and definately the thread. Would be fairly easy to adapt if you didn’t want to retain the LC sidestand braket as original.
Post by midlifecrisisrd on Feb 19, 2024 22:41:24 GMT 1
As above, pivot hole and bolt thread size bigger on a ypvs
Got one to try at some point (if I ever find the fecker again)
It may help with a sloppy hole 🧐
Post by jon on Feb 19, 2024 22:43:36 GMT 1
My sentiments exactly. Could be a good mod for those not too concerned about OEM?
Post by headcoats on Feb 19, 2024 23:10:17 GMT 1
I bought a nearly new LC side stand of fleabay and the seller had drilled it to accept a ypvs bolt 🙄
Post by midlifecrisisrd on Feb 19, 2024 23:25:28 GMT 1
Not compared them but was hoping it was a little longer too for a hybrid
Post by JonW on Feb 19, 2024 23:36:33 GMT 1
done it the other way as well, you just need a small spacer making for the frame hole.
Post by 4l04ever on Feb 20, 2024 0:38:50 GMT 1
Not compared them but was hoping it was a little longer too for a hybrid Steve I think they are the same length. There are different or no tabs on different models of side stand.
