Post by shane99 on Feb 17, 2024 16:54:15 GMT 1
Hi there
My Rd 350 lc is having carb issues it runs on both cylinders OK but only with the choke on if I take the choke I can rev it a bit then it dies, also ticks over him with choke in or out, I've turned in the air screw all the way and back out 1.5 turns doesn't make any difference. Im running 250 carbs with 350lc jetting and ramair pods. Any advice would be fantastic. 👍
Post by stusco on Feb 17, 2024 17:13:43 GMT 1
You need big jets for pod filters
Post by 4l04ever on Feb 17, 2024 17:13:57 GMT 1
The jetting will be way wrong, but probably not causing your high tick over issue.
The pod filters will need a lot bigger mains (300+++) and probably bigger pilot jets too. You will be way lean and will melt a piston running with those settings.
I would check the carbs have the correct handed slide and bowls as both are handed.
I would also do a leak down test, as an air leak will affect running.
Post by shane99 on Feb 17, 2024 17:23:58 GMT 1
The jetting will be way wrong, but probably not causing your high tick over issue. The pod filters will need a lot bigger mains (300+++) and probably bigger pilot jets too. You will be way lean and will melt a piston running with those settings. I would check the carbs have the correct handed slide and bowls as both are handed. I would also do a leak down test, as an air leak will affect running. Thanks for the help. Spoke to Al about a leak test kit. Will check carbs slides and bowls and will order bigger pilots and mains
