Post by steve99 on Feb 16, 2024 17:30:00 GMT 1
Hi all I have just got a pair of barrels and noticed one of the liners has been knocked and has a small dint. Do you think these will be ok to run? Thanks IMG_0007 by Steve D, on Flickr IMG_0008 by Steve D, on Flickr
Post by jon on Feb 16, 2024 17:34:56 GMT 1
I would say definitely yes. My logic is it looks like it was done before being rebored, so should be square?
Post by lcmarky on Feb 16, 2024 17:36:24 GMT 1
So long as the head gasket manages to seal should be fine I reckon, but if it were me I'd want to dress that face rid of any indentations & compensate with a thicker base gasket..
Post by steve99 on Feb 16, 2024 17:54:16 GMT 1
I did think about skimming the top thickness of a bottom gasket and fitting two bottom gaskets but concerned that would alter port timing
Post by steve99 on Feb 16, 2024 17:55:28 GMT 1
Bore on 1.5mm over size so not much to play with
Post by zed1015 on Feb 16, 2024 18:07:34 GMT 1
It'll be fine. Top ring doesn't come up that far and it's not big enough to affect the head gasket..
Post by yamman1066 on Feb 16, 2024 19:46:50 GMT 1
its fine
Post by linx on Feb 16, 2024 22:32:31 GMT 1
I wouldn't worry about it
