avb
andys vapour blasting
Post by avb on Feb 16, 2024 11:47:35 GMT 1
I've tried everything i know to remove a broken piece of baffle thats stuck in 1st plate.im going cut on inside of pipe and try that way.before the dremel comes out.us there a picture or one cut open? Only want one attempt at it
Post by reedpete on Feb 16, 2024 12:59:52 GMT 1
You need to cut between the spot welds (and allow 10mm clearance ) which you can usually see best from the inner side.
Post by tony2stroke on Feb 16, 2024 13:01:14 GMT 1
I've tried everything i know to remove a broken piece of baffle thats stuck in 1st plate.im going cut on inside of pipe and try that way.before the dremel comes out.us there a picture or one cut open? Only want one attempt at it There are some pics of cut exhaust on rd350lc.net
avb
Post by avb on Feb 16, 2024 13:02:35 GMT 1
Wondered where they were thanks pete
Post by Gitram on Feb 18, 2024 11:28:19 GMT 1
I tried to get a broken piece out using a magnet on a stick but it was too bashed about to get through the round hole for the baffle so out came the angle grinder with a 1mm cutting blade.. chopped a hole into the pipe on the back (between the welds) so it wouldn't be noticed, fished out the bit and held the part i had cut out with a couple of welding magnets so i could give it a weld and grind.. a quick skoosh of paint later and no visible signs to give the game away..
marti
avb
Post by avb on Feb 18, 2024 18:02:55 GMT 1
I tried to get a broken piece out using a magnet on a stick but it was too bashed about to get through the round hole for the baffle so out came the angle grinder with a 1mm cutting blade.. chopped a hole into the pipe on the back (between the welds) so it wouldn't be noticed, fished out the bit and held the part i had cut out with a couple of welding magnets so i could give it a weld and grind.. a quick skoosh of paint later and no visible signs to give the game away.. marti Thanks im taking it work tomorrow. Doing what you've doneits just the outer skin thats stuck.nearly had with a coat hanger Andy
