Post by nomoreheros on Feb 15, 2024 16:32:31 GMT 1
Can anyone recommend a good paint stripper... I've given Nitromors a go but feel like I'm wasting my time
Post by abar121 on Feb 15, 2024 16:37:57 GMT 1
Starchem stuff isn't bad.
Post by element137 on Feb 15, 2024 17:11:07 GMT 1
from bitter personal experience, brake fluid, ask me how I know...
Post by oldelsieboy on Feb 15, 2024 17:13:50 GMT 1
Post by linx on Feb 15, 2024 17:27:35 GMT 1
Frosts tank stripper 👍
Post by steeley on Feb 15, 2024 20:48:29 GMT 1
What are you stripping ? If it is a petrol tank with a failed liner i found this handy more than a few times .
Post by nomoreheros on Feb 15, 2024 22:31:02 GMT 1
What are you stripping ? If it is a petrol tank with a failed liner i found this handy more than a few times . Stripping engine casings
Post by steve63 on Feb 15, 2024 23:13:30 GMT 1
Yep. I have a gallon can of this and can confirm it's at least as good as Nitromors was when it actually could be described as paint stripper. The modern stuff is quite literally a waste of time. Mine went in the bin. It may have discoloured the paint.......slightly.
Post by shandyboy on Feb 15, 2024 23:22:48 GMT 1
Paramose is as good as you can get, Pro use only lol
Post by linx on Feb 15, 2024 23:24:35 GMT 1
I used some Screwfix paint stripper on a clutch cover recently. Left it on for 3 hours instead of the recommended 1 hour. Just made it sticky 😩
Post by donkeychomp on Feb 16, 2024 0:11:13 GMT 1
Proper nasty paint stripper like they used to make is still out there but it aint't cheap. About £50 for 5l. Worth it though when you can wash your hands in Nitromors. Starchem etc...that's what you need.
Post by Norbo on Feb 16, 2024 5:59:39 GMT 1
One thing i never used to get a cheaper alternative for was paint stripper always used to get the best c " Nitromors " But they changed the formula to conform with rules then it was as crap as all the rest .
Post by jackjabba on Feb 16, 2024 8:32:17 GMT 1
DCM - Dichloromethane, I think this is what they took out of Nitromors. Anyway it strips paint and will melt the soles of your shoes.
Post by donkeychomp on Feb 16, 2024 22:12:02 GMT 1
And burns you arse as I discovered when I accidentally sat on a tiny drop of it.
Post by steve63 on Feb 17, 2024 23:40:21 GMT 1
Paramose is as good as you can get, Pro use only lol We were given the tin of it by our painting contractors. They painted the inside of some stainless cable transits when we had masked them off with bolted plates. They actually took the plates off to paint them! They gave us the paint stripper so we could remove the paint. Our guys refuse to use it because one of the symbols on the tin represented "may cause cancer". Someone would have been ok to take it home for use in the garage so I made sure it was me. I remember proper Nitromors had difficulty with powder coating, not this stuff 😀
kevmc
Post by kevmc on Feb 21, 2024 2:19:53 GMT 1
Proper proffessional old school paint stripper from Steyer Ltd. Note: You will need to order through a company name
Post by darboots on Feb 21, 2024 9:11:17 GMT 1
This is what I recently used. Very potent stuff - worked really well.
Post by liffy16 on Feb 21, 2024 10:35:39 GMT 1
DCM - Dichloromethane, I think this is what they took out of Nitromors. Anyway it strips paint and will melt the soles of your shoes. This is what I've used to strip tank liners,proper nasty stuff used to get it off eBay in gallon can
Post by chrisg on Feb 21, 2024 19:15:10 GMT 1
The magic ingredient is MEK and is only available to the trade only. There was a guy on EB but would only sell if you had a company letter head. 😠
Post by jackjabba on Feb 21, 2024 19:18:56 GMT 1
The magic ingredient is MEK and is only available to the trade only. There was a guy on EB but would only sell if you had a company letter head. 😠 You can buy MEK on Amazon for £8.99 for 500ml.
Post by chrisg on Feb 21, 2024 19:40:34 GMT 1
The magic ingredient is MEK and is only available to the trade only. There was a guy on EB but would only sell if you had a company letter head. 😠 You can buy MEK on Amazon for £8.99 for 500ml. Weird because you cant buy paint stripper with MEK in it.
Post by charles13 on Feb 22, 2024 2:02:20 GMT 1
You can buy MEK on Amazon for £8.99 for 500ml. Weird because you cant buy paint stripper with MEK in it. Acetone and MEK are very similar, acetone is just a little more volatile.
Post by chrisg on Feb 22, 2024 11:27:54 GMT 1
Weird because you cant buy paint stripper with MEK in it. Acetone and MEK are very similar, acetone is just a little more volatile. I knew someone who tried to take some tar spots from his car with Acetone and it took the paint off , how we laughed 😁
Post by stirling11 on Feb 22, 2024 17:19:10 GMT 1
MEK is Methyl Ethyl Ketone, it’s good for stripping epoxy paints
It’s also highly carcinogenic
You’d probably have a better chance of finding a di-chloro-methane based stripper
Post by steeley on Feb 23, 2024 9:07:38 GMT 1
MEK is Methyl Ethyl Ketone, it’s good for stripping epoxy paints It’s also highly carcinogenic You’d probably have a better chance of finding a di-chloro-methane based stripper Hmmm , yes MEK not nice . We used it a lot at work with the right type of ppe . After reading a news letter of how a chap from a sister company got some in a cut on his finger which turned Nasty . This resulted in him losing his hand, the stuff in on stores vanished ,which was nice .
Post by steven on Feb 23, 2024 14:22:27 GMT 1
