Post by petehodges on Mar 18, 2010 22:59:09 GMT 1
Post by oldelsieboy on Mar 18, 2010 23:14:29 GMT 1
hi all got a metmachex arm on my lc rear wheels been off for a while and i,m a bit confused which and where the spacers go ?? some pics or advice would be great ,cheers pete If its a 4L0 rear wheel, these may help OEB
Post by petehodges on Mar 18, 2010 23:31:16 GMT 1
thanks for that ellsieboy but i,ve got vavle wheels on it which adds to the confusion ,pete
Post by oldelsieboy on Mar 19, 2010 10:27:32 GMT 1
Any good
Post by petehodges on Mar 19, 2010 18:43:37 GMT 1
Any good thanks mate got the manual but it just doesnt look right too me
Post by petehodges on Mar 20, 2010 23:24:11 GMT 1
anyone
Post by Shytalk on Mar 21, 2010 11:06:00 GMT 1
Looks to me like you're missing a collar on the sprocket side, should be similar to the one on the disk side. Even so the bar that the calipers mounted on looks like its rubbing the end of the swinger too.
Post by oldelsieboy on Mar 21, 2010 13:30:50 GMT 1
Looks to me like you're missing a collar on the sprocket side, should be similar to the one on the disk side. Even so the bar that the calipers mounted on looks like its rubbing the end of the swinger too. Isnt the spacer on the disc side usually part of the caliper hanger bracket?
Post by petehodges on Mar 21, 2010 20:42:06 GMT 1
Looks to me like you're missing a collar on the sprocket side, should be similar to the one on the disk side. Even so the bar that the calipers mounted on looks like its rubbing the end of the swinger too. Isnt the spacer on the disc side usually part of the caliper hanger bracket? yes mate is on a standrad arm but mines a metmachex so theyre used diffrent spacers trouble is if think i,ve lost some as its not working out and i,m a bit at a lost
