Post by wassy06 on Feb 9, 2024 21:14:22 GMT 1
The left fork leg on my N1 has always leaked. I’ve replaced the seal and bushes with genuine yam ones but they don’t seem to last a season so I’m either going to replace the stantion or send both legs off to Philpotts to be re chromed. Alternatively there are two brand new stantions on eBay part numbers 1UA-2311-00 and 51L-23110-00 would either of these fit. TIA 👍🏻
Post by midlifecrisisrd on Feb 9, 2024 23:09:48 GMT 1
You'd have to check the part number but the 51l one would be most likely
1ua tops don't screw in
Post by wassy06 on Feb 9, 2024 23:36:42 GMT 1
Checked the Fowlers diagram and it looks like the 51L are circliip as well so neither suitable.
Post by midlifecrisisrd on Feb 10, 2024 0:33:40 GMT 1
Checked the Fowlers diagram and it looks like the 51L are circliip as well so neither suitable. Just looked Yamaha Rd350lc 1985 Shows forks as screw in top and 51L part number RZ250 51L was near identical to an F1 57v N1 and F1 had the same forks I'm also sure Norbo does repro ones, had a pair a few years ago Steve
Post by wassy06 on Feb 10, 2024 0:46:24 GMT 1
Checked the Fowlers diagram and it looks like the 51L are circliip as well so neither suitable. Just looked Yamaha Rd350lc 1985 Shows forks as screw in top and 51L part number RZ250 51L was near identical to an F1 57v N1 and F1 had the same forks I'm also sure Norbo does repro ones, had a pair a few years ago Steve Thanks, I’ve sent the seller a question re the threaded top so will see what he says. I’ll drop Norbo an email as well to see if he has any in stock.
Post by wassy06 on Feb 10, 2024 16:26:28 GMT 1
You are right the 51L is threaded. Are they all the same length I know they are all 35mm.
