Post by stusco on Feb 7, 2024 17:27:26 GMT 1
Im making up a sub loom to extend the wires from my zeel so i can fit it in the tail nice and neat ,what size of cable do you suggest? Im not up on wire dimensions and need to order some from kojaycat
Post by 4l04ever on Feb 7, 2024 22:44:16 GMT 1
1mm2 would work, but I would go up to 1.5mm2 to avoid any volt drop. ALM do lots of wires too :- www.almsolutions.co.uk/
Post by stirling11 on Feb 9, 2024 15:03:46 GMT 1
Before you buy, check to see what current the wire can carry
1mm2 from one manufacturer can vary greatly from another
The more strands the less resistance and hence less voltage drop and of course more current, check on that too
Also make sure you check that it’s the square mm measurements and not the cross section diameter,
The two are completely different
A good 1mm2 wire will carry 15 amps, a bad only 5, and the good one will have about 30 strands, the el cheapo only 10
Post by stusco on Feb 9, 2024 20:37:12 GMT 1
The stuff i ordered has 21 strands and rated 21amps
Post by midlifecrisisrd on Feb 9, 2024 20:43:42 GMT 1
Jeez, you jumpstarting the Audi off that 🤣
Zeel and Iggy are under 5a so you are well safe there 👍
Post by stusco on Feb 9, 2024 20:50:42 GMT 1
I did say i didn’t know 🤷♂️
Post by 4l04ever on Feb 9, 2024 21:12:26 GMT 1
It can never be too thick.....at least that is what my Mrs says...
Post by stusco on Feb 9, 2024 21:14:05 GMT 1
It will fit the 6mm crimps better
Post by 4l04ever on Feb 9, 2024 21:14:15 GMT 1
also....the new thin wall 1.5mm cable looks close to the OEM 1mm cables due to the older wiring having thicker insulation.
Sub loom
Feb 10, 2024 11:46:38 GMT 1
via mobile
Post by midlifecrisisrd on Feb 10, 2024 11:46:38 GMT 1
Admittedly the thinner wires don't crimp easily in the bigger connectors
I tend to crimp then solder them
A good solution for electrical connection but can cause a brittle point
Post by jon on Feb 10, 2024 12:01:24 GMT 1
Admittedly the thinner wires don't crimp easily in the bigger connectors I tend to crimp then solder them A good solution for electrical connection but can cause a brittle point Steve I’ve also soldered connectors as well as crimping in the past. I get the logic some people say it creates a brittle point, but I’ve never had a problem. Jon
Sub loom
Feb 10, 2024 12:15:33 GMT 1
via mobile
Post by midlifecrisisrd on Feb 10, 2024 12:15:33 GMT 1
Think it's more where there is a lot of vibration
Never had a problem either
Post by 4l04ever on Feb 10, 2024 12:20:34 GMT 1
Soldering is good if the connection is not moving about. If it is moving or flexing, then crimping is better.
Post by Tobyjugs on Feb 10, 2024 12:29:21 GMT 1
In The past i have read not to solder connectors on vehicles etc. Personally i thought fussy buggers. My Bakker bike creates more vibration than a standard bike and the only wire which i soldered failed. Maybe just coincidence but i try to avoid soldering now.
Post by jon on Feb 10, 2024 12:36:46 GMT 1
In The past i have read not to solder connectors on vehicles etc. Personally i thought fussy buggers. My Bakker bike creates more vibration than a standard bike and the only wire which i soldered failed. Maybe just coincidence but i try to avoid soldering now. Purely out of interest which wire was it? Jon
Post by Tobyjugs on Feb 10, 2024 12:45:02 GMT 1
In The past i have read not to solder connectors on vehicles etc. Personally i thought fussy buggers. My Bakker bike creates more vibration than a standard bike and the only wire which i soldered failed. Maybe just coincidence but i try to avoid soldering now. Purely out of interest which wire was it? Jon It was an earth connector from the rpm meter to the chassis i used an old connector which i cut off another wire and soldered it.
Post by jon on Feb 10, 2024 12:47:20 GMT 1
I see. I use non insulated connectors and only solder the clip bit not the strain relief bit. So in theory the wire still remains flexible from the connector end.
Post by JonW on Feb 10, 2024 12:50:26 GMT 1
Solder joins, crimp connectors...
Post by Tobyjugs on Feb 10, 2024 12:55:45 GMT 1
I see. I use non insulated connectors and only solder the clip bit not the strain relief bit. So in theory the wire still remains flexible from the connector end. Jon Hi Jon i use non insulated connectors an then insulate them with the correct plastic sheath. I'm not really to savvy when it comes to Electrickery. There are so many different types of connection blocks to choose from, i always wonder which is the best type. To be honest i really don't like those coloured plastic connectors and only use them when i have no other choice. In the past i have had a small bollocking via PM about my wiring from a member here. I always look up to him so 9 times out of ten i listen to him and take his advice very seriously.
Sub loom
Feb 10, 2024 20:31:44 GMT 1
via mobile
JonW likes this
Post by midlifecrisisrd on Feb 10, 2024 20:31:44 GMT 1
I too tend to only solder the wire crimp and not the bit that grips the insulation
I do wonder if it's the non flexibility from the soldering or the heat affecting the copper
And those coloured crimps should be nowhere on a motorbike 🤣
Post by JonW on Feb 10, 2024 23:42:32 GMT 1
I too tend to only solder the wire crimp and not the bit that grips the insulation I do wonder if it's the non flexibility from the soldering or the heat affecting the copper And those coloured crimps should be nowhere on a motorbike 🤣
Steve SO TRUE! (and using Scotchlocks should mean you get a rap in the knuckles with a hammer)
Post by 4l04ever on Feb 11, 2024 10:00:58 GMT 1
Soldering the wire basically converts it from flexible multi stranded to a solid core which will stress crack if bent many times.
