Post by scootjockey on Feb 5, 2024 23:13:03 GMT 1
Evening im after a bit of advice im using an aftermarket speedo with electronic rev counter pick up has anyone found a suitable cap/cover for the rev counter drive at the crankcase ?
I was thinking of using the original cable and cutting it and using the screw adaptor with a rubber insert to prevent oil leaks. That's unless I can't find a suitable plastic bottle top ? Anyone know the diameter of a coke bottle lol š
Cheers Gaz
Post by headcoats on Feb 5, 2024 23:30:45 GMT 1
Post by scootjockey on Feb 5, 2024 23:43:35 GMT 1
Oooh ere missus that's very bling ! And just the job as the plastic tacho drive is a 4LO part used on loads of models Thank you very much !!
Post by JonW on Feb 6, 2024 0:33:28 GMT 1
if youre splitting the cases, whip the tacho drive parts out and fit the 85-on blanking bung... (drop me a line if you do that, I'd like your old tacho parts )
Post by reedpete on Feb 7, 2024 7:10:26 GMT 1
@ Gaz, Norbo sells them too. @ John if you need Rev counter drive etc then I have plenty of spares hereā¦
red998
Post by red998 on Feb 7, 2024 9:30:49 GMT 1
That's interesting. I have a lathe and could probably make one fairly easily if I could get round to it. Does anyone know the thread pitch?
Post by reedpete on Feb 7, 2024 9:37:03 GMT 1
If you want to go down that Yambits route then surely the easy way is to use an old Rev counter cable as a donor, cut the cable and take off the bit that screws on and just put a disc insideā¦
Post by andy748 on Feb 7, 2024 17:06:29 GMT 1
Trick i saw years ago was chop the end off your rev counter cable and glue a 1p piece in the screw end, stick it on and away you go, cheap as chips, well a penny. Andy.
Post by reedpete on Feb 8, 2024 5:40:08 GMT 1
Trick i saw years ago was chop the end off your rev counter cable and glue a 1p piece in the screw end, stick it on and away you go, cheap as chips, well a penny. Andy. Funny you should say thatā¦ I woke up wondering which of a 1/2p or 1p would be best fit !
