Post by 4l04ever on Jan 31, 2024 22:43:51 GMT 1
dex46
Post by dex46 on Jan 31, 2024 22:48:09 GMT 1
Wish I had learnt how to strip and build engines when I was at school it’s good to see that they are eager to learn
Post by 4l04ever on Jan 31, 2024 22:53:37 GMT 1
The engine is seized so needs some further investigation and some brute force :-)
Post by sheep911uk on Jan 31, 2024 23:08:00 GMT 1
I promised you a challenge !!!
Post by 4l04ever on Feb 6, 2024 0:03:29 GMT 1
Got the flywheel and stator off.
Post by 4l04ever on Feb 6, 2024 0:05:03 GMT 1
Post by sheep911uk on Feb 6, 2024 8:50:12 GMT 1
Great job so far, let’s hope there’s no nasty surprises lurking in the bottom end !!!!
Post by 4l04ever on Feb 6, 2024 17:44:16 GMT 1
Will continue investigations tomorrow.
Post by sheep911uk on Feb 6, 2024 19:18:35 GMT 1
Looking forward to seeing the next chapter!
Post by 4l04ever on Feb 7, 2024 20:58:17 GMT 1
Spent another hour on it. Managed to get the right hand cylinder about 20mm further up, but not quite off yet. Looks to be stuck on the casing studs as the piston is now moving. Also got the engine casing off. Found one random bolt in the clutch basket so far. More oil was still coming out and it was very dirty!
Did not get time for pics but will try to get some tomorrow.
Post by 4l04ever on Feb 8, 2024 21:43:28 GMT 1
Post by sheep911uk on Feb 8, 2024 21:45:08 GMT 1
Great work
Post by 4l04ever on Feb 19, 2024 18:59:24 GMT 1
Post by 4l04ever on Feb 19, 2024 18:59:58 GMT 1
Post by urbantangleweed on Feb 20, 2024 7:52:42 GMT 1
It's very satisfying getting an engine apart that really doesn't want you to.
Post by JonW on Feb 21, 2024 0:48:54 GMT 1
I agree... and at that point you also hope youve had the last of the 'bad surprises'... one can always hope!
Post by sheep911uk on Feb 21, 2024 14:31:25 GMT 1
I agree... and at that point you also hope youve had the last of the 'bad surprises'... one can always hope! Fingers crossed
Post by 4l04ever on Feb 21, 2024 23:04:27 GMT 1
Post by sheep911uk on Feb 22, 2024 11:18:48 GMT 1
Top work Kids !!!
Post by urbantangleweed on Feb 22, 2024 13:39:17 GMT 1
Doesn't look too bad in there?
Post by lcmarky on Feb 22, 2024 15:03:57 GMT 1
My kind of schooling!!
Post by 4l04ever on Feb 26, 2024 21:51:52 GMT 1
Engine fully stripped now.
Casing ready for blasting.
Crank is welded and all crank bearings are shot, so bin fodder... Need to remove the primary gear, but the backlash numbers are way out...
Clutch basket fingers are worn quite bad so it will need a new basket or a better one to tidy up.
Post by zig on Feb 26, 2024 21:53:36 GMT 1
Engine fully stripped now. Casing ready for blasting. Crank is welded and all crank bearings are shot, so bin fodder... Need to remove the primary gear, but the backlash numbers are way out... Clutch basket fingers are worn quite bad so it will need a new basket or a better one to tidy up. i managed to purchase a set from Dave @ Mutts great price and no hassle ZiG
Post by 4l04ever on Mar 9, 2024 19:33:23 GMT 1
Cleaned up top casing. Before After
Post by JonW on Mar 10, 2024 1:06:35 GMT 1
what a transformation! (i think that everytime i see this done )
Post by LC_BOTT on Mar 10, 2024 13:57:36 GMT 1
Has someone 'flowed' the crankcase inlets, looks a bit wobbly around the gasket faces. Otherwise looks like they've done a good job with the clean-up.
Post by 4l04ever on Mar 10, 2024 14:25:55 GMT 1
It has had some weird adjustments to the lower transfer area.
Post by archloafer on Mar 10, 2024 22:45:41 GMT 1
Excellent stuff. An ugly but satisfying job, by the look of it.
Post by 4l04ever on Mar 11, 2024 18:43:14 GMT 1
Spare bottom end dropped off by Nick. Stripped by the kids today. Gears look good. Crank not welded so should be good for rebuilding.
Post by 4l04ever on Apr 29, 2024 17:31:58 GMT 1
Removed the engine studs. Blasted them and cleaned them up. Had them plated with the corrosion resistant black. I will do this on all my future rebuilds after having cylinders stuck on corroded studs. The gear selector shaft hole has had a bush fitted too.
