Post by linx on Jan 31, 2024 20:43:14 GMT 1
Hi all,
Just recieved an adpter kit to lift my LC2 on my Skylift. They sent me kit 066. Is that the right one? Seems to fit the pivot bolt head well but seems a bit loose on the nut.
Cheers Linx
Post by stusco on Jan 31, 2024 21:10:58 GMT 1
Email them with the size you want and they will send you them (you might have to pay) but if they supplied the wrong set ? I had to do this but I don’t remember what bike it was for
dex46
Post by dex46 on Feb 1, 2024 22:57:33 GMT 1
Hi all, Just recieved an adpter kit to lift my LC2 on my Skylift. They sent me kit 066. Is that the right one? Seems to fit the pivot bolt head well but seems a bit loose on the nut. Cheers Linx I’ve had the same experience not using a sky lift just using a super bike stand fitted good on the 22mm head but loose on the 19mm nut not sure if it’s the same on a 31K mine is on a Lc also found not enough clearance for gearshift and brake pedal what I’ve done is use a deep 22mm & 19mm socket packed out and pressed into the fittings for a tight fit and works a treat will upload pics Tomorrow once in the garage hopefully that will help no main stand is a bugar at times Dex
Post by linx on Feb 8, 2024 7:53:36 GMT 1
Emailed Abba. They are sending me a 19mm adapter FOC 👌
Post by mangocrazy on Feb 12, 2024 12:27:53 GMT 1
After reading this thread I went and checked on the Abba kit I ordered 2 or 3 years ago but have never used. The fitting for the 19mm nut was perfect - a nice snug fit with no movement. However the fit on the 22mm head of the bolt was sloppy AF. So I've pinged off an email and will see what happens.
Post by linx on Feb 12, 2024 12:45:30 GMT 1
After reading this thread I went and checked on the Abba kit I ordered 2 or 3 years ago but have never used. The fitting for the 19mm nut was perfect - a nice snug fit with no movement. However the fit on the 22mm head of the bolt was sloppy AF. So I've pinged off an email and will see what happens. Interesting. Mine was the other way round. They will want the order number.
Post by mangocrazy on Feb 12, 2024 14:42:48 GMT 1
After reading this thread I went and checked on the Abba kit I ordered 2 or 3 years ago but have never used. The fitting for the 19mm nut was perfect - a nice snug fit with no movement. However the fit on the 22mm head of the bolt was sloppy AF. So I've pinged off an email and will see what happens. Interesting. Mine was the other way round. They will want the order number. Mine were for a 4L0 350LC, whereas yours were for an LC2 as far as I can see. That may be the cause of the confusion? I'll dig out the order number - I'm pretty sure I still have the email trail.
Post by freddie19 on Feb 12, 2024 20:27:43 GMT 1
How does this fit on and lift an LC2? 🤔
Post by stusco on Feb 12, 2024 21:07:38 GMT 1
Swingarm spindle
Post by freddie19 on Feb 13, 2024 0:25:45 GMT 1
Is that it, doesn't seem very secure especially with the spindly swingarm bolts on LC's........not like the massive drilled swingarm spindle bolts fitted to modern bikes!!! 😱🤔
Post by stusco on Feb 13, 2024 8:33:56 GMT 1
It works fine for me I’ve built three bike on mine lc,lc2,rg400
Post by midlifecrisisrd on Feb 13, 2024 9:32:22 GMT 1
It really is no problem
You put your £15k superbike on a paddock stand that are attached by m6 bolts
Also consider the wheel spindles are 12mm and 15mm
Weight of the bike, rider, pillion, potholes and humps in the road and they are fine
