Post by stusco on Jan 30, 2024 16:34:30 GMT 1
Anyone fitted one im finding a few of the connections are wrong ie the cdi connection is male where it should be female the generator one was the same and they are not cheap,these are round pins. The coil connection was the wrong as well this isn’t round pin also the rear brake light now that I think of it
Post by midlifecrisisrd on Jan 30, 2024 18:10:28 GMT 1
Nightmare
I nearly bought one when they were reduced last year but was worried this would be the case
Post by stusco on Jan 31, 2024 20:40:35 GMT 1
I contacted them today and was told they are an exact copy of the 4l0 loom and all the connections are correct,so i have sent pictures and waiting a reply
Rob123
Post by Rob123 on Jan 31, 2024 21:22:31 GMT 1
Hi, I bought one last year in June and remember the ad saying it was older stock and they were on offer for £206 I thought I'd take the risk at that price. I was pleasantly surprised all connectors were correct and wires were as thick as originals which I was worried about. I wonder if they changed supplier. Rob
Post by jon on Jan 31, 2024 21:34:49 GMT 1
I been scratching my head recently on building a new LC loom. But it’s more to do with the self cancelling wiring. A wrong connector is definitely not right.
Post by shaunthe2nd on Jan 31, 2024 21:39:15 GMT 1
I have a couple of well butchered looms I use as donors for my own builds. Many connectors already stripped off, but if I have any of the ones you need I'm happy to help. Just ping me details and pics and will have a look for you.
Post by stusco on Jan 31, 2024 22:18:03 GMT 1
This one of the wrong connections Im not using the cdi its for info only both connections are male
Post by shaunthe2nd on Jan 31, 2024 23:24:56 GMT 1
I'm sure on the standard loom that male-female connections are always the same colour. There's a black to black 3 pin for the cdi and a white to white 3 pin for the alternator, and its this one that usually burns out. Hopefully someone will confirm as I'm going off memory.
Post by reedpete on Feb 1, 2024 7:11:26 GMT 1
Post by stusco on Feb 1, 2024 8:24:53 GMT 1
Looks like yours were correct
Post by stusco on Feb 1, 2024 8:25:38 GMT 1
I'm sure on the standard loom that male-female connections are always the same colour. There's a black to black 3 pin for the cdi and a white to white 3 pin for the alternator, and its this one that usually burns out. Hopefully someone will confirm as I'm going off memory. All the connections on the new loom are white
Post by jon on Feb 1, 2024 19:32:24 GMT 1
That’s pretty poor to have the wrong terminal on. I suspect Legend don’t build them themselves? But whoever is, is not paying attention. All the same it’s their reputation for poor products, and there have been a few.
Most people who buy new looms are doing so because they can’t repair or build one themselves?
Why not phone Legend and see if they will sort it out for you?
Post by stusco on Feb 1, 2024 20:52:30 GMT 1
Im in contact with them they are phoning me tomorrow,but so far they don’t believe me even with photo evidence
Post by jon on Feb 1, 2024 21:35:35 GMT 1
Let all of us know how you get on. Many have had bad experience of customer service.
How can they question photographic evidence?
Post by stusco on Feb 1, 2024 21:37:18 GMT 1
Apparently someone has changed the connectors on all the images of lc cdi’s on the web
Post by jon on Feb 1, 2024 21:43:28 GMT 1
Can you post the email response in this thread?
Post by stusco on Feb 1, 2024 21:46:17 GMT 1
Maybe after I’ve spoken/resolved the issue with them i just want the correct plugs i can fit them myself
Post by mark69 on Feb 1, 2024 22:34:44 GMT 1
I’ve bought one of these recently, haven’t taken it out of the bag yet. Watching with interest.
Post by jon on Feb 1, 2024 22:48:17 GMT 1
OK, your pictures are not that clear with the wire colours covered by you fingers, but I’m starting to think the loom is correct?
It was the fact you mentioned about web images being wrong? Surely you would make a loom from checking components not the web?
Anyway I think it’s that CDI that’s been butchered. The plug it should fit into has been chopped off by the looks of it. No wonder the coil connector seemed wrong also.
They should be a male and female 3 pin connector on both the loom and the coil. The reason the plugs are black and white is probably to stop some idiot plugging it in incorrectly without looking at the corresponding wire colours?
Post by shaunthe2nd on Feb 1, 2024 23:20:39 GMT 1
I'm confused too, so looking forward to finding out a bit more info.
Post by jon on Feb 1, 2024 23:36:02 GMT 1
I’ll try and explain.
The white plug you show on the loom has male pins. It also clearly shows an orange wire. This is to the coils. It should connect to a female pin white plug on the CDI. I think yours has been chopped off and replaced with 1/4” spade connectors?
The black male 3 pin connector from the CDI should go to another connector on the stator plate with black, brown and red wires.
Post by stusco on Feb 2, 2024 8:31:56 GMT 1
Cheers you could be right ill check tonight,but it still short by 50mm at the back and ive had to change other connections male to female
