Post by sheep911uk on Jan 29, 2024 8:48:54 GMT 1
I have just removed the engine from my project bike, would it be ok to cover the up any openings to the internals and put it in a parts washer and give it a brush over?
Post by urbantangleweed on Jan 29, 2024 9:14:28 GMT 1
Should be fine if you can be sure the cleaning fluid doesn't get where it doesn't belong.
Post by sheep911uk on Jan 29, 2024 10:40:16 GMT 1
Should be fine if you can be sure the cleaning fluid doesn't get where it doesn't belong. Will block the exhaust ports, reed blocks and top hose, spark plugs are in so should be ok.
Post by headcoats on Jan 29, 2024 11:17:00 GMT 1
I wouldn't. Strip it and do it properly and you can check all the internals and replace anything that needs it
Post by sheep911uk on Jan 29, 2024 12:27:56 GMT 1
I wouldn't. Strip it and do it properly and you can check all the internals and replace anything that needs it It’s going to be stripped I wax just going to give it a once over as it’s been stood for 20 Yrs!!
Post by linx on Jan 30, 2024 18:20:15 GMT 1
I've done this before. No problem. Just use a brush and some engine cleaner. Don't jet wash!
Post by geoffers997 on Feb 3, 2024 8:30:40 GMT 1
I got 5 litres of general purpose degreaser from screwfix and used it with a small brush and bucket of water to give mine a general once over to get rid of the worst of the crud before I got into it and did a proper clean on individual parts once stripped.
As said, seal up all the holes and don’t jet wash
