Post by sheep911uk on Jan 26, 2024 23:07:06 GMT 1
Are there any videos on how to remove the oil pump cable on a 350lc?
Post by shaunthe2nd on Jan 27, 2024 10:20:03 GMT 1
It's pretty straight forward, only tricky bit is lifting the spring return in the pulley enough to release the cable without withdrawing the spring fully out and allowing it to ping out. I'm not aware of a video, but its covered well enough in Haynes from memory.
Post by JonW on Jan 30, 2024 0:42:30 GMT 1
yep, pretty easy once you get started.
The pump spring is a weird bit of design from Yam that proves this pump wasnt originally for this purpose lol
Look at the parts book to see where the clip is etc.
