Post by sheep911uk on Jan 22, 2024 11:29:20 GMT 1
Are the 31k calipers the same as used on the 4lO ?
Post by reedpete on Jan 22, 2024 11:47:06 GMT 1
No, but the early LC2 ones will fit as the spacing of the mounting holes is same. 31K N1/F1 had different calipers
Post by sheep911uk on Jan 22, 2024 11:53:15 GMT 1
No, but the early LC2 ones will fit as the spacing of the mounting holes is same. 31K N1/F1 had different calipers Thanks they will be up for sale then along with the rest of the front end as I’m led to believe that’s 31k too!!!
Post by JonW on Jan 22, 2024 13:33:16 GMT 1
In theory the early LC2 calipers are better than the LC... but im not 100% sure you'd notice it lol
Post by yamman1066 on Jan 22, 2024 18:45:44 GMT 1
Post by crogthomas on Jan 24, 2024 13:44:05 GMT 1
What makes them better?
Post by steve63 on Jan 24, 2024 13:50:51 GMT 1
I think the sliding pin is enclosed at the end and could be thicker/stronger. The one on my SR125 looks like a 31K calliper.
Post by midlifecrisisrd on Jan 24, 2024 16:19:18 GMT 1
As above
Same size pistons but the slides were on a steel bracket. Think there were 2 slide pins
A better design than the LC's set up
Post by JonW on Jan 26, 2024 23:39:27 GMT 1
yes, 'technically better' but not a night/day difference, just a mild upgrade.
