Post by arrdy350 on Jan 18, 2024 7:49:07 GMT 1
I am going to put the reed vavles on later do I need to put gasket sealer on them if I am using a genuine gasket ? Also do you put some sealer on the clutch cover gasket aswell if you are using a genuine one of them?
Many thanks Arrdy 🙂👍
Post by urbantangleweed on Jan 18, 2024 7:57:03 GMT 1
If they're the metal type, they usually have a bead of sealer already on them and are supposed to be fine.
Personally, I've found they leak far too often for my liking so I prefer to fit a gasket made from normal gasket material.
I also use a coat of spray Hylomar on all gaskets (except head of course....) as it helps them seal and makes dissasembly/cleaning up the faces easier if, or as and when, the time comes.
Post by dusty350 on Jan 18, 2024 8:18:24 GMT 1
I put 3bond on inlet gaskets. Prime place for an air leak, so even genuine gaskets get a smear of the goo. Clutch case shouldn't need it unless there are any bad gouges or damage to the surfaces. A leak here will be annoying but not potentially catastrophic as with the inlets.
Post by midlifecrisisrd on Jan 18, 2024 8:28:26 GMT 1
Wot E Said
I've had dry gen reed gaskets leak before
Post by JonW on Jan 18, 2024 8:45:49 GMT 1
always glue the reeds in now... ive had so many leak in testing.
...and thats even after Ive dress the cylinders with a sharpening stone to knock down the pulls on the reed's bolt threads...
if youve not done this you might be shocked how pulled up these can be.
Post by stusco on Jan 18, 2024 8:47:06 GMT 1
I use a thin smear of silicone gasket sealant (oil resistant hightemp)the same stuff i use on my exhaust,clutch casing ,all gaskets in fact it comes in black or clear i have both,but its just a very thin layer i reuse the clutch casing one again no problem
Post by beardy on Jan 18, 2024 9:03:38 GMT 1
On the Reed valves I use Blue Hylomar. The last time I had the clutch cover off was a few years ago and I used a genuine gasket. I noticed that parts of the gasket came with gasket goo already applied. So I just cleaned the whole area up and put the gasket on dry. Still no leaks today 👍🏻
Post by liffy16 on Jan 18, 2024 9:28:04 GMT 1
Use three bond on inlet and crankcase ,dry on clutch ,head gasket and base gasket
Post by abar121 on Jan 18, 2024 11:06:55 GMT 1
Yep, three bond or similar fuel resistant sealant. As above, they love to leak.
Post by arrdy350 on Jan 18, 2024 11:14:56 GMT 1
Thank you very much everyone for the replies 👍
Post by 4l04ever on Jan 18, 2024 18:04:52 GMT 1
I fit metal head gaskets dry, reed block pattern gaskets with Threebond, and all other gaskets with a thin smear of grease to allow easy disassembly in the future.
Post by 84rzrider on Jan 19, 2024 17:39:48 GMT 1
I use Permatex anaerobic sealant on the reed cage gaskets for the same reasons noted above and I also use a reed cage gasket coated on both sides between the intake rubber and the reed cage even though it isn't required. Works perfectly and wipes right off even years later with a bit of brake kleen on a rag.
