Post by 4l04ever on Jan 16, 2024 21:57:41 GMT 1
Roger ( urbantangleweed) said he needed a special gasket making.... I spent an hour and got this drawn up....
Post by 4l04ever on Jan 16, 2024 21:59:59 GMT 1
Pic
Post by urbantangleweed on Jan 16, 2024 22:10:09 GMT 1
You sir, are a bluddy star! 😊
Post by donkeychomp on Jan 16, 2024 22:16:06 GMT 1
Best gasket maker out there. I use Rob's stuff on everything.
Post by midlifecrisisrd on Jan 16, 2024 22:30:03 GMT 1
I take it that it is a gasket for a ypvs thermo housing for running no stat?
Post by 4l04ever on Jan 16, 2024 23:12:54 GMT 1
Yes, in theory....
Roger is fitting a modified thermostat housing with no room for a stat.
Post by donkeychomp on Jan 16, 2024 23:14:19 GMT 1
So Roger is dodging the stat?
Sorry, sorry...
Post by 4l04ever on Jan 16, 2024 23:19:53 GMT 1
3 gaskets made...
Post by urbantangleweed on Jan 17, 2024 7:26:59 GMT 1
I take it that it is a gasket for a ypvs thermo housing for running no stat? Steve Yes, but it's more complicated than that. I can't get the usual housing in on MT2 because it's in the way of the rad so a mate tigged a modified FZR400 housing (which has the outlet at 90 degrees and at the back) to a 55 degree 'stat spacer, then another spacer under that gives the outlet stub clearance over the head bolts behind it, so, each time it's installed, 2 gaskets are required. I had cut my own to get her up and running initially, but they look like I did.......
Post by urbantangleweed on Jan 17, 2024 7:28:48 GMT 1
3 gaskets made... Mega! They look the bees knees! Cheers Rob!
Post by peter1962 on Jan 17, 2024 18:03:51 GMT 1
Quick question, do you make gasket's for other parts of the bike (350 4l0)?
Post by stusco on Jan 17, 2024 18:12:16 GMT 1
Quick question, do you make gasket's for other parts of the bike (350 4l0)? Oh yes and other bikes 😁 im sure he will advise shortly www.oldmoto.co.uk Is his web site
Post by chrisg on Jan 17, 2024 19:36:03 GMT 1
Is there a possibility of making a 350 (4L0) copper head gasket? Im sure it would be popular as it would be re useable and the OE ones are pricey (read: extortionate) .
Post by 4l04ever on Jan 17, 2024 20:00:03 GMT 1
I make all the gaskets on the 4L0 bikes apart from head gaskets. Same for YPVS.
I make some gaskets but not all for RD500, TZR250 1KT, 2MA and 3XV, RD125LC, TZ350, TZ250 4DP, KR1S, RGV250 VJ22, Aircooled RD250/400, Suzuki GT750 and RG500.
I also make Banshee Vforce reed block gaskets.
I had some 4L0 cylinder aluminium spacers made in 0.5, 0.8mm and 1mm thicknesses.
And I make fuseboxes for LC, YPVS and Aircooled bikes.
I better get round to sorting a website out again...
Post by bezzer on Jan 17, 2024 20:14:01 GMT 1
Rob, Did you get any further replicating the gasket that goes between the clutch basket and drive gear?. Looks quite tricky to plot!.
Cheers Bud. Iain.
Post by 4l04ever on Jan 17, 2024 20:22:57 GMT 1
I did make the LC Clutch Basket internal gasket. There is one on test with Muttsnuts to make sure they are good before going into production.
Post by bezzer on Jan 17, 2024 20:41:55 GMT 1
I did make the LC Clutch Basket internal gasket. There is one on test with Muttsnuts to make sure they are good before going into production. Brilliant mate, well done, another item formerly made of unobtanium, may become available again.
Post by 4l04ever on Jan 19, 2024 16:37:21 GMT 1
Roger's gaskets posted out :-)
Post by lcmarky on Jan 19, 2024 17:32:12 GMT 1
This forum is ace - Great work!
