Post by Jethro5 on Jan 11, 2024 10:17:03 GMT 1
Could somebody who has refurbished a 250 1/2 inch master cylinder confirm 100% they normally have the extra small relief hole. I have been attempting to clear the place where it looks like there is a hole with no luck. I ground down a hacksaw blade small enough to fit though the small hole in a 350 master cylinder. However I cannot push it through the 250 master cylinder hole. Looking down the bore I cannot see any sign of a hole as I can on the 350. The unit has the sight glass that clips in. Therefore I want to confirm before I damage something.
Post by chrisg on Jan 11, 2024 17:55:31 GMT 1
Yes there are 2 holes. I used a piece of wire from a wire brush held with some pliers to clean out the small hole. It is known for blocking and prevents the pads from returning.
Post by Jethro5 on Jan 11, 2024 21:53:56 GMT 1
Thanks for confirming. Thought it must have one but it is solid. I’ll persevere.
Post by Gitram on Jan 12, 2024 15:06:34 GMT 1
had similar recently, the hole was solidly blocked and i couldn't poke through the hole, soaked the MC in vinegar, whether that helped or not, who knows but was then able to get a thin welding nozzle tip cleaner into the hole to clear out the blockage..
marti
Post by chrisg on Jan 13, 2024 16:21:49 GMT 1
A last resort would be to use a micro drill, best guess 0.5mm dia. , but be careful not to snap it or you will be a world of poop.
Post by Jethro5 on Jan 14, 2024 23:42:01 GMT 1
Ended up getting it clear by grinding down an old Allen key that I could fit through the 350 hole. Then carefully tapped through with a hammer. It was seriously blocked. No way a strong wire would have cleared it.
Post by chrisg on Jan 15, 2024 13:15:24 GMT 1
Ended up getting it clear by grinding down an old Allen key that I could fit through the 350 hole. Then carefully tapped through with a hammer. It was seriously blocked. No way a strong wire would have cleared it. Every day is a school day.😉
Post by Gitram on Jan 15, 2024 16:01:47 GMT 1
Ended up getting it clear by grinding down an old Allen key that I could fit through the 350 hole. Then carefully tapped through with a hammer. It was seriously blocked. No way a strong wire would have cleared it. glad you got that sorted.. it's the simple things that sometimes throw you off track and you know that you are right but there's a doubt.. which is why there are no silly questions.. I tried mine with the usual bit of copper wire but it wasn't strong enough to go through the blockage. marti
