G
Post by G on Jan 3, 2024 18:31:00 GMT 1
Hi
I'm refurbing a 31m swinging arm for a project and wondered whether its possible to switch out the bushes on the main shaft pivot and replace with the bearings from and F1?
Thanks
Post by freddie19 on Jan 3, 2024 20:41:36 GMT 1
Not sure on that one mate but I know my 1985 RZ350 swingarm has needle roller bearings fitted from the factory.
It's basically the same swingarm as the 31k LC2 so there should be no real issues in getting them to fit.👍
Post by JonW on Jan 4, 2024 0:23:34 GMT 1
Mine has needle rollers, I bought a kit from NK.
Post by midlifecrisisrd on Jan 4, 2024 9:56:47 GMT 1
I'd think it needs a specific bearing, not just the F1 bearings
End caps, thrust washers (only on F1 type) and centre pivot tube are different
G
Post by G on Jan 4, 2024 14:10:29 GMT 1
Mine has needle rollers, I bought a kit from NK. Ok thanks I've asked Nigel
G
Post by G on Jan 4, 2024 17:27:51 GMT 1
Mine has needle rollers, I bought a kit from NK. Sadly doesn't make them any longer
Post by JonW on Jan 4, 2024 23:16:45 GMT 1
Mine has needle rollers, I bought a kit from NK. Sadly doesn't make them any longer Ahh, thats a shame as it was a nice bit of kit. Yambits did a needle roller kit for the LC. I fitted that to my 251LC, it wasnt great as a kit but works ok. Do they do an LC2?
Post by freddie19 on Jan 5, 2024 17:27:46 GMT 1
G
Post by G on Jan 5, 2024 23:48:58 GMT 1
Yep I also looked into it further. Removing the old main pivot spacers with the flanges means you'd need to add 2.5mm each side to compensate if using the roller bearings. I'd decided to stick with the existing as they are in surprisingly good condition
Post by freddie19 on Jan 6, 2024 0:01:52 GMT 1
Yeah...... that's what the thrust washers and end caps are for!
Post by JonW on Jan 6, 2024 13:07:14 GMT 1
yep, Think of it this way, the caps are 1mm thick and the thrust washers are 1.5 on both sides.
With the other kits a cut spacer/thrust was included that sat inboard to locate it and then the required distance outside. NKS version worked well.
FYI the LC yambits kit used bearings with loose needles, it wasnt a fun thing to fit cos of that. These caged units look much better.
