Post by stevesmith on Jan 3, 2024 14:34:48 GMT 1
Hello all.. Is anyone in here s**t hot on internet ,wifi, router, voip etc etc... Need to get a connection to the other side of the house ,so I can use the internet and voip calls. We have fibre to house, then a cat 6 cable running to the other side of the house - (wired internet) but now need to get a connection for the phone (voip) Only thing I can think of is running another cable (for phone ) and plug that into the back of our router... WiFi breaks down ,so that's not a option really.. Any ideas TIA Steve
Post by arrow on Jan 3, 2024 14:40:25 GMT 1
Wow, you must have a big place. My WiFi is full signal here, in every room.
Post by arrow on Jan 3, 2024 14:42:33 GMT 1
Some BB providers can provide you with a home booster, can't they?
Post by linx on Jan 3, 2024 14:44:49 GMT 1
Take a look at powerline. Uses the electric circuit as a data network. Can then go wired or wireless from the power line plug. Does need to be on the same ring main.
Post by steve63 on Jan 3, 2024 14:48:05 GMT 1
Take a look at powerline. Uses the electric circuit as a data network. Can then go wired or wireless from the power line plug. Does need to be on the same ring main. That's what I have. TP Link. Works fine.
Post by arrow on Jan 3, 2024 14:48:36 GMT 1
Take a look at powerline. Uses the electric circuit as a data network. Can then go wired or wireless from the power line plug. Does need to be on the same ring main. My lad used to use one of those for gaming, but I didn't know they could be wireless as well.
Post by 4l04ever on Jan 3, 2024 14:51:24 GMT 1
Is there CAT6 cabling near where you want the phone? A wired connection will be preferable to Wi-Fi. If the cabling comes out where you want the phone, just add a switch like this one :- www.argos.co.uk/product/8495459
Post by linx on Jan 3, 2024 14:51:40 GMT 1
Take a look at powerline. Uses the electric circuit as a data network. Can then go wired or wireless from the power line plug. Does need to be on the same ring main. My lad used to use one of those for gaming, but I didn't know they could be wireless as well. I guess you need to buy the correct version but they definitely do both.
Post by stevesmith on Jan 3, 2024 14:54:09 GMT 1
Wow, you must have a big place. My WiFi is full signal here, in every room. Granny annexe - too many walls and the WiFi cuts out... Hence the wired internet...
Post by stevesmith on Jan 3, 2024 14:56:53 GMT 1
Is there CAT6 cabling near where you want the phone? A wired connection will be preferable to Wi-Fi. If the cabling comes out where you want the phone, just add a CAT6 switch like this one :- www.argos.co.uk/product/8495459We have a cat6 connection the other side ( internet is now wired ) problem being is the filters they supply for the old phones to work on the new VoIP are rj11... All the ones I've seen like the ones you've linked ar rj45... I've tried different connections rj45 - rj11 and the bloody phone won't work ... Plug it into the back of our modem/router and it works fine ... I hate technology
Post by 4l04ever on Jan 3, 2024 15:01:12 GMT 1
What model VOIP phone do you have? Does it plug into an RJ11 connector on the router?
Post by arrow on Jan 3, 2024 15:02:04 GMT 1
I'm pretty sure one of my customers is a bt open reach engineer. I'll ask him the question for you....
Post by stevesmith on Jan 3, 2024 15:08:32 GMT 1
What model VOIP phone do you have? Does it plug into an RJ11 connector on the router? It's my parents old bloody phone (big numbers etc etc ). Basically on our side you plug into the back of the router via a rj11 connection - This is the filter they supply so you can use the old phones. It works fine our side - but not their side (no router / modem ) on their side... I did think about adding a model/router their side... But you cant have 2 modems/ routers connected.... "So I've been told"
Post by arrow on Jan 3, 2024 15:15:57 GMT 1
What model VOIP phone do you have? Does it plug into an RJ11 connector on the router? It's my parents old bloody phone (big numbers etc etc ). Basically on our side you plug into the back of the router via a rj11 connection - This is the filter they supply so you can use the old phones. It works fine our side - but not their side (no router / modem ) on their side... I did think about adding a model/router their side... But you cant have 2 modems/ routers connected.... "So I've been told" I spoke to the guy. He knows how to do it, but its too much for me to type. He said you can call him directly after 4 pm. I'll pm you his number.
Post by arrow on Jan 3, 2024 15:20:39 GMT 1
Done. 👍
Post by 4l04ever on Jan 3, 2024 15:22:28 GMT 1
