Post by chud786 on Dec 19, 2023 1:36:11 GMT 1
I've got an Athena gasket set and it came with 2 paper gaskets and 3?? metal ones.The old ones I removed were metal. Which ones do you recomend I replace them with? Bike is an F2
Post by 4l04ever on Dec 19, 2023 7:30:57 GMT 1
Use the metal ones if they have sealant on them.
If you use the paper type,apply a thin smear of three bond.
Post by dusty350 on Dec 19, 2023 8:21:06 GMT 1
+1 on 3bond on these gaskets. This is usually a prime place for air leak, so some sealant is always a good idea
Post by urbantangleweed on Dec 19, 2023 8:47:33 GMT 1
I use the paper type with a light coat of spray hylomar. Had air leaks with the metal ones and never have with my preferred method.
(Rob (4l04ever) supplies good gaskets)
Post by midlifecrisisrd on Dec 19, 2023 8:55:10 GMT 1
As Rob says the metal ones with the bead of sealer are like the original and usually work well
Any paper/fibre gasket will need some kind of sealer, even the genuine Yamaha ones 🙄
Post by Chewie01 on Dec 19, 2023 11:54:57 GMT 1
freddie19
Member is Online
Post by freddie19 on Dec 19, 2023 22:14:27 GMT 1
The 31K metal gaskets are NLA they have been replaced by the paper ones 3GG-13621-00.
I bought some myself from Fowler's this year!
Post by chud786 on Dec 19, 2023 23:34:21 GMT 1
Thanks for all the replies,very helpful info. I think I'll go for the paper ones with some sealant.
Post by 4l04ever on Dec 19, 2023 23:54:12 GMT 1
I can supply good quality gaskets, as I make them myself :-)
